Thread: Unpleasant Surprise
Results 1 to 8 of 8
  1. Unpleasant Surprise
    Jan 2010
    Inverness, Scotland
    I had the cam belt changed this week, when the guys at my local Audi specialists took the car for a drive, they heard a knocking sound, further investigation revealled a blocked oil pick up pipe, which was effectively depriving the engine of oil. The mechanic suggested the car's previous history of long life servicing may have been a contributing factor. I have had the car almost 2 years, and have had an annual service done since I've owned the car. The mechanic advised me to get rid of the car ASAP. They did notice an improvement in the engine when the pipe was replaced, but are worried that some damage has been done, which could potentially lead to a huge repair bill in the future. The car is a 2005 A4 2.0 tfsi quattro s-line. Has anyone experienced this issue before?
    Regards, Gerry
  2. Re: Unpleasant Surprise
    Sep 2008
    chester
    17 Post(s)
    I'm a diesel man myself but I believe its a common problem with these's cars,it would no doubt be doing it no good but whether its going to be catastrophic in the long run its anyones guess,you may have been lucky and got it just in time,if its quiet now you should be ok,longlife servicing would have contributed to this.
  3. Re: Unpleasant Surprise
    Aug 2009
    Near Lanark
    21 Post(s)
    that's a concern....I have a 2006 version of the same car.
    How many miles are on your car? high miles?
    What is long life servicing....I mean what constitutes a long life service interval?
    I bought my car privately and the maximum service interval hasn't been anymore than around 10k (I have FSH).
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  4. Re: Unpleasant Surprise
    Oct 2010
    London, England
    Quote Originally Posted by darich View Post
    Audi Variable Servicing (AVS for short), is the system by which the car monitors the way you drive and works out for itself when it needs to be serviced, subject to a maximum of two years or 20,000 miles. If your car is on AVS, it must be filled with longlife oil. I am not a fan of this.
    You can have the AVS system switched to fixed intervals, in which the on board service indicator will flash up when one year or 10,000 miles elapses.
    A4 3.0TDi SE Quattro Tiptronic in Quartz Grey.
    On order: S4 Black Edition Saloon in Tornado Grey with Fine Nappa black/silver leather.
  5. Re: Unpleasant Surprise
    Jan 2010
    Inverness, Scotland
    My milage is 70900, the long life servicing was apparently every two years, Audi apparently use long life oil. The car had 65000 miles on the clock when I bought it. It has a full service history, including my servicing which has been annual, the car has been serviced 4 times.
    Regards, Gerry
  6. Re: Unpleasant Surprise
    Aug 2009
    Near Lanark
    21 Post(s)
    Thanks Gerry
    My car is on 50k approx and from memory has been serviced 4 or 5 times already.
  7. Re: Unpleasant Surprise
    Aug 2009
    Reading England
    I have a 2.0 tdi 170 and its been on the long Life from new and its hit 177K without any problems (5 years old)
    BUT for petrol engines im not sure, but for diesel I can not fault the LL service.
    Audi A4 B7 2.0 Tdi S Line 170.
  8. Re: Unpleasant Surprise
    Jan 2011
    Chester
    quite often on turbocharged cars - the oil can carburise and block feed pipes. This happens when the car is driven hard and then switched off without the turbo being allowed to cool - the oil around it overheats. hence why you should always idle a turbo'd car before you turn off the engine if you've just given it a bootfull or two....
  1. Please Help Unpleasant smell from air con
    By saj.3 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-08-2011, 10:03 AM
  2. Passat 1.8 TSI Unpleasant Resonance While Engine Revs at 1200 RPM
    By theshark in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 10-06-2011, 08:56 AM
  3. Surprise surprise AKL problems
    By maximus659 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-12-2009, 08:38 PM
  4. New Car Salesv - Surprise Surprise
    By ashadam in forum Chat - Anything with wheels
    Last Post: 04-09-2008, 09:33 PM
  5. My VAGCOM wont work (surprise surprise!)
    By Audi A4 Lover in forum VCDS - General Questions
    Last Post: 18-06-2008, 01:11 PM
