Thread: 245 to 255 discs upgrade.
Results 1 to 10 of 11
  1. 245 to 255 discs upgrade.
    Nov 2011
    Newcastle upon tyne
    has anyone upgraded to 255 discs on the rear.is it a case of changing the caliper carrier and discs ?
  2. Re: 245 to 255 discs upgrade.
    Nov 2011
    Newcastle upon tyne
    I have now wasn't to hard thanks for all the help !
  3. Re: 245 to 255 discs upgrade.
    Jul 2008
    Uranus
    Out of curiosity, what was it that lead you to the conclusion that the rear brakes on your car needed upgrading?
    Also, what did you do to correct the front/rear bias that you've upset by improving your rear brake efficiency?
    May 2008
    Can you honestly tell any difference when braking?
  5. Re: 245 to 255 discs upgrade.
    Nov 2011
    Newcastle upon tyne
    with drilled and grooved discs yes,or could be that rear discs were that knackered any thing would be an improvement but I cant help tinkering.If it can be done why not,besides the new discs were cheaper than standard 245's.
  6. Re: 245 to 255 discs upgrade.
    warp_speed Guest
    Quote Originally Posted by Pork View Post
    Actually I don't think the front/rear bias is an issue in cars any more with multichannel ABS systems. Used to be when ABS was fitted to the front only, that's if was fitted at all. I know that there would have been a pressure limiting valve fitted to the rear circuit, some of which were weight dependent..... that's just my 10p worth.
  7. Re: 245 to 255 discs upgrade.
    Nov 2011
    Newcastle upon tyne
    I set out to up grade the front and rear brakes it's just the rears have been done first. I intend to upgrade the front brakes to 315 discs fom the 288's the reason being I like to make a car stop quicker before I make it go faster,and as said before all discs needed replacing anyhow and the rear's were in the worst state.
    To increase the disc size just means fitting the caliper carrier from the right model.In may case a 2.0T a4 b6 or b7 both run bigger brakes than the tdi.
  8. Re: 245 to 255 discs upgrade.
    Mar 2010
    Lyneham
    I have a few questions about rear brakes, if any one can help?
    Does any one know what size rear brake disc's for an Audi A4 2.0tdi S-line (55reg)?
    Does any one know what size rear brake disc's for an Audi A4 2.0tdi SE (07reg)?
    Is it possible to change from 245/10 disc's to 255/12 disc's, without changing anything else?
    Will Audi A4 2.0tdi SE (07reg) rear disc's (if different) fit an Audi A4 2.0tdi S-line (55reg)?
    Also, are the rear pads the same for these two cars?
    I thank you in advance for your replies
  9. Re: 245 to 255 discs upgrade.
    Nov 2011
    Newcastle upon tyne
    pretty vague as so many options on audi's
    1) are they i40 or 170 bhp ?
    2)pads are the same wether they are 245's or 255's
    3)if you go up to 255's on the rear you'll have to change the caliper carrier (the brkt holding the caliper to the sub frame.I have done this mod on my own avant and sorced the carriers from a scrap yard,I believe some 1.8T and 2.0T's 2001-2008 ran the bigger brakes.)
    4) you can also do the same on the front by going 288 x 25 to 312 x 25 once again you need to change the caliper carrier as the caliper and pads are the same.
    ps at the same time I upgraded to drilled and grooved disc's ,fairly cheap of ebay.Hope this helps.
  10. Re: 245 to 255 discs upgrade.
    Mar 2010
    Lyneham
    Thanks for your reply!
    Sorry forgot to state: Audi A4 2.0tdi S-line (55reg) = 140bhp
    Audi A4 2.0tdi SE (07reg) = 170bhp
    Do you know what size rear brake discs fit each car?
  1. Snowchains 245 x 40 x 18
    By Harrythecat in forum Wheels and Tyres
    Last Post: 26-04-2011, 09:25 PM
  2. Will 245 tyres fit my A6?
    By DukesA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-11-2010, 05:55 PM
  3. 255 or 235 tyres
    By carlos-1975 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-09-2010, 03:22 PM
  4. Question Will 245/40/18 fit my b6 sport
    By wmaiden in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-06-2010, 04:13 PM
  5. Attention Audi A6 MMI-High upgrade discs
    By PhantomBlack in forum New Member Introductions
    Last Post: 19-10-2009, 09:19 PM
