Thread: new member with power steering issue
Results 1 to 10 of 12
  1. new member with power steering issue
    Nov 2011
    london
    Hello everyone, I'm new to the forum, I've just purchased a 2008 golf gt tdi 140, the problem I have is when I have the steering near on full lock but not quite full on and pull away from a standstill I get this noise as if I have no fluid in the steering but apparently it doesn't use fluid, is that correct? Any ideas what it could be? It doesn't happen if the car is at a standstill and I'm turning the wheel, its only as I pull away! Any help is much appreciated, cheers
  2. Re: new member with power steering issue
    Leics
    As far as I know all Mk5's use power steering fluid and I would check the level in the reservoir.
    Any clicking or knocking noise on turning (at slow speed on full-lock) would normally indicate to me a lack of constant velocity joint lubricant, possibly due to a damaged gaiter. Or a worn outer c.v. joint.
  3. Re: new member with power steering issue
    Aug 2008
    All Mk5's have electric assisted power steering,so have no fluid reservoir at all.They can make some odd noises when on the extremes of lock,usually nothing to worry about as long as the noise is not particularly loud.
  4. Re: new member with power steering issue
    108 Post(s)
    1816 Post(s)
    Would you say this heading covers it "mooing noises in bends" or is it only when turning left?
  5. Re: new member with power steering issue
    Nov 2011
    london
    it is a mooing noise but only when pulling away with the steering near on full lock, I'm not 100%
    Sure but I think it maybe only when turning to the left, I will check for sure after work, what do you suggest that could be? Thank you
  6. Re: new member with power steering issue
    Leics
    Quote Originally Posted by sky5020 View Post
    Sorry mav84, sky5020 is correct, and I stand corrected. My Haynes manual for the Mk5 Manual No. 4610 makes reference to a Power steering fluid level check under the Contents section of Chapter 10, but when one reads further into the chapter it confirms that there are in fact no hydraulic components. How ambiguous and misleading. I apologise for my mistake. How embarrassing!
  7. Re: new member with power steering issue
    108 Post(s)
    1816 Post(s)
    The mooing when pulling away is normal degraded transmission fluid so a change of gearbox oil usually stops it and I like to add Slick 50 gearbox treatment to help. The noise when turning left normal indicates a faulty steering rack although re greasing the rack and pinion gears can help sometimes.
  8. Re: new member with power steering issue
    Nov 2011
    london
    Ok well it is also doing it when I steer to the right! Not as much I don't think but its for sure making the same noise. How comes it only makes a noise to the left if it was to be the rack? Thanks for your help
  9. Re: new member with power steering issue
    108 Post(s)
    1816 Post(s)
    That is due to the design of the rack.
  10. Re: new member with power steering issue
    Sep 2011
    glasgow scotland
    my jetta makes a noise alsoonly full left lock but was told it was normal
  1. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  2. Please Help Steering Issue
    By clarky26 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2010, 12:24 AM
  3. Golf Mk3 Power Steering Issue
    By monty130 in forum Golf MK3 - 1993 - 1999
    Last Post: 28-03-2010, 01:56 PM
  4. Power Steering Issue with 1994 Audi Coupe
    By minimadjamm in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 04-07-2009, 07:36 PM
  5. power steering issue
    By stevesco in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2008, 07:37 PM
