Thread: Help please - 2.0TDI pulling right under power
  1. Help please - 2.0TDI pulling right under power
    May 2008
    Hi folks,
    A little help if at all possible.. Currently have the good ladies Passat Estate in the garage as I noticed it pulling right under acceleration (generally at speed it's worse) - pull back left when you get off the power. The MOT a couple of weeks ago picked up nothing so they've got it back in today for them to have a good look.
    They have come back with they agree there is something wrong (i.e. the car does pull), but there is nothing substantially wrong (they can find a small amount of play in one of the suspension arm bushes, but nothing excessive). I have noticed that there is a creak on the suspension when going over speed humps - and a search of the forum shows this to be a known issue, however I can't see how this will be causing it to pull as there would be excess movement somewhere. Tracking has also been checked and is spot on. The garage are stumped and don't want to change the arm as they think it's OK.
    Any ideas/experience/advice gratefully accepted!
    Thanks in advance
    James
    Current - FL A6 Avant 2.0 Ultra BE S-Tronic, Tornado Grey, 20" titanium alloys
    Previous - 2012 - A6 Saloon S-Line 2.0TDI, Daytona Grey, 19" 7 Twin spokes, DAB
    The good ladies - 2014 Golf GT 1.4 TSi ACT - Black
  2. Re: Help please - 2.0TDI pulling right under power
    Apr 2010
    Ashford, Middlesex
    This might sound a bit silly, but have you checked the tyres and tyre pressures?
    I had a similar issue recently (pulling left under acceleration, albeit not badly, and handling/riding generally like a bag of spanners); being pre-occupied with moving house, I hadn't checked my tyre pressures in ages - when I did them on Saturday, every one of them was at least 0.6 bar under inflated - since inflating them properly, the issues have gone.
    In your case, it could even be a tyre out of true or similar?
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
    Nov 2006
    derbyshire
    What sort of alignment gear did they use to check tracking. Could be a bent suspension arm. had bad experience with some so called laser alignment. they will see if it's bent when they compare old to new. Is there any unusual gearbox whines or noise?
  4. Re: Help please - 2.0TDI pulling right under power
    Jan 2013
    kiddy
    Quote Originally Posted by JamesMo View Post
    Hi folks,
    Thanks in advance
    James
    Did you ever solve your problem???
    Assuming you are still on the forum..lol
  5. Re: Help please - 2.0TDI pulling right under power
    May 2008
    Hi, still here and still in the land of VW and Audi, but we don’t have the Passat anymore. From what I remember, I took it to another alignment place with a Hunter 4 wheel alignment system, they checked it and found a slight variance to the first place - they tweaked it and all was well.
    good luck
    J
  1. Please Help car is pulling, brake jammed, slows quickly off power.
    By sillydior in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-01-2010, 04:21 AM
  2. s reg 1.6 polo...no pulling power..plese help
    By domross in forum Polo - Derby - Lupo - Fox
    Last Post: 04-10-2009, 10:45 PM
  3. 1995 Transporter 800 1.9tdi lacks pulling power
    By Howesmob in forum The Commercial Range
    Last Post: 03-05-2009, 01:56 PM
  4. Power Loss when pulling off
    By golftdi02 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-02-2008, 07:20 PM
  5. Golf 1.8t Mk4 Pulling power
    By Bevsy in forum Archive posts
    Last Post: 24-11-2007, 04:12 AM
