Thread: third/centre brake light
  1. third/centre brake light
    Mar 2008
    North-East
    Have found out that the third/centre brake light in the passat is not lighting up correctly- very dim across all of it. no warning lights in the dash.
    How long should these last?
    Can't see how to get to the light to replace the bulb from the hatchback lid, and nothing helpful in the handbook either.
    Any advice on how to replace, costs, or is this a dealer only job?
    Amir
    Passat Estate Sport TDI 170 DSG/ Golf GT TDI 140
  2. Re: third/centre brake light
    134 Post(s)
    2005 Post(s)
    New light unit 1K6 945 097 A £42.37 (the old one was £28.12!)
    Switch off ignition and all electrical consumers and disengage ignition key or start button by moving to position 0 (pre-detent).
    To prevent damage to paintwork, stick a strip of commercially available adhesive tape on paintwork of roof spoiler above high-level brake light bulb -M25-.
    Caution
    Ensure the seal is not damaged when removing the additional brake light.
    Insert wedge -T10039/1- between upper edge of high-level brake light bulb -M25- and roof spoiler as shown in illustration.
    Press brake light downwards and unclip upper brake light locking lugs to rear using wedge -T10039/1-.
    Then pull the high-level brake light bulb -M25- to rear out of opening in the roof spoiler, as far as the connected wiring allows.
    Note. If the high-level brake light bulb -M25- cannot be removed as described, please contact the TSC or the importer.
  3. Re: third/centre brake light
    Mar 2008
    North-East
    thanks for the reply
    looks a bit too fiddly for me to do without damaging something...
  1. Very Dim Rear Centre Brake Light
    By Cruella De Vil in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2020, 04:02 PM
  2. centre brake light removal plz a6 06 avant
    By sthalab in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-04-2011, 02:29 PM
  3. Intermittent centre brake light on A4 cab
    By ricola in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-11-2010, 11:24 PM
  4. Avant centre brake light
    By HUTCH2.7tdi in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-06-2010, 09:03 PM
  5. No Brake lights only centre light on
    By chillin_uk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-05-2008, 10:25 PM
