Hy everyone.Recently noticed that when I try to clean the windscreen, the water coming out of the washers only goes to about half way up the windscreen.I remember when I first bought the car the jet spray used to go all the way up to the top of the windscreen,over the top of the car and some would even land on the back windscreen.I've tried to poke the small washer nozzles with a needle and it doesn't look as if they're blocked.could there be a blockage in the pipes from the water reservoir to the washers??.has any of you guys experienced this problem before.any advice or sugestions are very welcome.
