Thread: bora tdi heater coil lightflashing
  1. bora tdi heater coil lightflashing
    May 2006
    does anyone know what the fault is?
    ta
  2. coil light
    Jun 2006
    I had the same problem on my MK4 Golf TDI150, this was after i was messing with my tail lights and had a bulb missing, so my advice would be to check all your tail lights and make sure you have the correct bulbs. A mate of mine had the same problem and cost him £40 from VW to diagnose the fault. Failing that then it could be your glow plugs.
    Hope this helps.
    Jun 2006
    Droitwich, Worcestershire
    Hi, just thought i would throw this one in, ive read in my manual that if a diesel engine develops a fault, the glow plug light will flash. Probably worth taking it into a garage and getting it hooked up to a laptop and see whats going on.
    Hope that helps.
  1. coil springs
    By panther in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-05-2007, 06:10 PM
  2. early A6 reader coil
    By beaky in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-04-2007, 05:56 PM
  3. ignition coil help...
    By SanderCH in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-02-2007, 04:36 PM
  4. Coil failure
    By Skii in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 05:42 PM
  5. front right coil spring
    By xiangyu19 in forum Beetle 2000-
    Last Post: 10-12-2006, 04:46 PM
