Thread: How to drain coolant in vw touran?
Results 1 to 10 of 10
  1. How to drain coolant in vw touran?
    May 2010
    Swindon, UK
    Hello. Got a 2004 touran 1.9LTDI. I attempted to change the coolant but unfortunately cannot proceed as i am having difficulty finding the drain plug. Can anyone help me with these or possibly provide photos so I can easily find it. Many thanks in advance.
  2. Re: How to drain coolant in vw touran?
    1840 Post(s)
    If it has one it will be on the outlet pipe on the lower left corner of the radiator.
    May 2010
    Swindon, UK
    Sorry to sound ignorant. What does it look like? I have tried looking around the radiator but cant find one. Does all tourans got one?
    May 2010
    Swindon, UK
    When you say lower left of the radiator, is it when your underneath the vehicle? Thanks.
  5. Re: How to drain coolant in vw touran?
    1840 Post(s)
    The left of the radiator is on the left of the car, looking at it from below on the back of the radiator, looking forwards. You cannot see it from above, you have to get underneath with the lower cover off and then you will see a tap which you rotate anticlockwise and the water will flow BUT release the system pressure first or coolant will be forced out under pressure.
    May 2010
    Swindon, UK
    Thanks crasher. I shall try and look for it again. Do i need to undo some pipe to drain as some forum adviced or it will all drain from the drain plug? And lastly does it need bleeding to get air our from the system?
  7. Re: How to drain coolant in vw touran?
    1840 Post(s)
    The drain point is a tap so you should collect the coolant and take it for proper disposal. The system self bleeds as you run it up.
    May 2010
    Swindon, UK
    Thank you so much crasher. I shall attempt to do it end of the week. Wish me luck. Cheers mate.
  9. Re: How to drain coolant in vw touran?
    Dec 2009
    Dublin
    I've just changed the coolant in a transporter t5 I removed the coolant temp sensor to drain is this acceptable? Also I blew through the coolant bottle a few times which pushed more water out. Anyway my problem now is I have no hot air in the cab. I'm guessing trapped air in the heater matrix? Also it only took 5 litres of coolant I thought it should of been 8? Any help appreciated and sorry if I'm hijacking your tread!
  10. Re: How to drain coolant in vw touran?
    Dec 2009
    Dublin
    Also can't find bleed screw is the t5 a self bleed system?
  1. Where is the coolant drain?
    By Spacer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-04-2011, 01:02 AM
  2. Touran battery drain
    By julesprice in forum Touran - Sharan - Caravelle
    Last Post: 24-08-2009, 09:33 PM
  3. Coolant Drain
    By NickPicks in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2008, 12:16 AM
  4. How to drain coolant?
    By TeK in forum Golf MK4 - 1999 - 2004
    Last Post: 16-05-2008, 10:33 AM
  5. How to drain the coolant
    By n1kh3l in forum Golf MK4 - 1999 - 2004
    Last Post: 17-11-2007, 10:22 AM
