Thread: Dreaded ESP Warning after 10 mins driving. Fault Code 18265
Results 1 to 10 of 15
  1. Exclamation Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    Apr 2010
    Leeds
    Hi guys can anyone help! My 2005 Audi A6 2.7TDI S-Line throws up a an ESP fault after driving for 10 minutes. Once the ignition is off it clears and returns again after 10 mins of driving. The fault reads "ESP Fault see owners manual" then disappears leaving the Traction control light on. The car drives perfectly with no juddering or loss of power throughout. My local garage could only supply me with a code.
    The code is 18265 (Engine Load signal??)
    Any help that could avoid a dealer visit would be fantastic.
  2. Re: Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    Oct 2005
    18265/P1857/006231 - Load Signal: Error Message from ECU - See here for details
    In which module/component did the code appear?
    Is it an auto or a manual?
  3. Re: Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    Apr 2010
    Leeds
    Its a Manual pal
  4. Re: Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    Mar 2009
    Helsingborg, Sweden
    Found this earlier thread, maybe it could be something for you:-
    https://www.vwaudiforum.co.uk/forum/s...8265-and-00526
    2012 VW CC 2.0 TDi
  5. Re: Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    Apr 2010
    Leeds
    What do you mean by which component? The garage suggested it was an ABS fault code but I'm not sure
  6. Re: Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    Apr 2010
    Leeds
    There was only one code not both like in the thread above.
  7. Re: Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    Mar 2009
    Helsingborg, Sweden
    Hi again,
    Sorry about that, but have just found this, its a pretty long thread but it seems to make sense:-
    http://www.audiforums.com/forum/audi...vealed-147482/
    2012 VW CC 2.0 TDi
  8. Re: Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    Oct 2005
    Quote Originally Posted by Lbcvantage View Post
    Its a Manual pal
    The fault code above usually appears within a specific module/component section in the diagnostic scan - it's not a part-specific code.
    Do you have someone local who can scan the car using VCDS?
  9. Re: Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    Apr 2010
    Leeds
    That's gone beyond my technical knowledge mate. I have been advised the code translates to P1857 if that helps. The fault occurs exactly 10 mins after starting, even if not moving! What is the car doing after 10 mins to cause it?? MAF has been mentioned a bit... I've just had a bulb replaced that required air box removal, could this be connected? Maybe a sensor disturbed?? I was told the filter was in a bad way too, again could this cause the problem? I'm clutching at straws!!
  10. Re: Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    Oct 2005
    Heh!
    Ross-Tech's VCDS (formerly known as VAG-COM) is software which will scan your car for trouble codes and give you an easy to follow report.
    In my post up there ^ I link to Ross-Tech's Wiki site for the codes.
    I own VCDS as do a lot of other nerds on here so the chances of someone in Leeds having a copy are fairly high.
    Have a search through this post for people in or around your area and then see if (a) they still have their copy, (b) they're still happy to scan and (c) if they can get a more comprehensive diagnosis/information.
    The MAF could be a possibility, especially as someone's been ferreting around the area already.
    I keep saying it, so my apologies for saying it again, but it all depends *where* this fault code is being stored. See the image on this page for a rough idea of how many different modules there are to scan.
  1. Emmision warning light - fault code
    By audi_black in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-03-2011, 12:42 PM
  2. Dashboard warning lights. Is this the dreaded ABS pump fault?
    By ProDave in forum Touran - Sharan - Caravelle
    Last Post: 22-01-2011, 11:22 AM
  3. interittent esp light fault codes 18265 and 00526
    By nickeym1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-02-2010, 10:28 PM
  4. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  5. ABS warning light after 10 mins of driving, V6 4motion
    By nemeth782 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2008, 01:48 PM
