Thread: Audi 'Long Life' service & service indicator
Results 1 to 8 of 8
  1. Audi 'Long Life' service & service indicator
    May 2010
    Loughborough, UK
    So how does this work, i.e. I understand the long life service gives a service interval that is not a fixed amount of miles, but mine's gone off after 20,000 miles. Isn't this the 'normal' service interval? Is there a different kind of reset for long life, or is this to indicate something other than a full service needs doing?
    53 plate 2.0tdi SE, 3 door
  2. Re: Audi 'Long Life' service & service indicator
    Jan 2010
    Wakefield, West Yorkshire
    The longlife service is variable interval and the car works out when a service is due depending on your driving style. Normal service interval is 10,000 miles. The service indicator is reset by the garage using VCDS or similar.
    20,000 miles is the maximum interval before service and I think this is explained in the service book.
  3. Re: Audi 'Long Life' service & service indicator
    Apr 2010
    staffordshire
    If your car is on the later longlife, after "08", there are three service events. The first is the only variable part, which is the oil sevice, this occurs anytime upto a maximum of 2 years & mileage between 9000 & 19000. The second event is the inspection, which is mileage based, every 19000 miles & the third is the time based, which is basically a brake fluid change, which is 3 years for the first BFC & then every 2 years after.
    What generally will happen is youroil service will come on a little before the inspection is due, if it's only a couple of thousand before the inspection the dealer will usually ask if you want both services carrying out at the same time. That's done to prevent you keep having to return to the dealer.
  4. Re: Audi 'Long Life' service & service indicator
    Jan 2010
    His car is a '53' plate baylissboy - do the same rules apply ?
  5. Re: Audi 'Long Life' service & service indicator
    Apr 2010
    staffordshire
    Quote Originally Posted by Mike Foster View Post
    Short answer is no.
    If anything the earlier cars are a little simpler. longlife is upto a maximum of 2 years & between 9000 & 19000 miles depending how the car is used. What usually happens is the service indicator comes on at 19000 or 2 years, which ever happens first & there is no warning for BFC, that should be every 2 years. Personally, I think Audi changed it because 19000 is too far for the oil, that's why they had so many turbo failures etc. Generally, the oil service for the later cars comes on before the inspection is due.
    2 0 0
  6. Re: Audi 'Long Life' service & service indicator
    Jan 2011
    East Kent
    That's interesting baylissboy; so if I have understood correctly (ignoring the brake fluid), basically the newer cars generally have their longlife oil changed earlier than the older cars do and then they have an inspection service later on (when the suspension etc. is checked)? Whereas the older cars have the longlife oil go for longer and then the oil is changed and an inspection service is done at the same time?
    Quote Originally Posted by baylissboy View Post
    Short answer is no.
    I've got a 55 plate and my service is due in a couple of weeks at about ~19200. I do very little town driving, mostly A roads. You say that you think that 19000 is too long for the oil, so do you have any personal recommendations please?
  7. Re: Audi 'Long Life' service & service indicator
    Jan 2010
    Short answer is no.
    Thanks for the answer baylissboy. Is it to do with the new CR engine that the oil change interval has been altered ?
  8. Re: Audi 'Long Life' service & service indicator
    Apr 2010
    staffordshire
    It's only a personal thing, but I'd never let my oil go 19000 miles! Longlife serviceing was designed for lease companies, who don't want to pay for serviceing, that's the main reason that the BFC interval is 3 years for the first & every 2 after, with the thought that many of the lease deals are for 3 years from new!
    It really does depend on how many miles you do a year. I run a MK5 Golf 2.0 TDI, I do approx 9-10k miles every year, so for me it's better to have fixed serviceing ie every 12 months, so every 12 months the oil is changed & every 24 months the car has an inspection. If you do that sort of mileage, that's what I'd recommend, if you do more, then longlife could be better.
    Later longlife wasn't introduced purely for the CR engine, it was brought in across the whole range, as I previously said, I feel it was done for the oil going too long mainly in cars covering low mileage in towns etc. Audi change service intervals on fuel filter etc all the time, mainly on model introduction, probably because they've seen failures of components & want to precent further issues.
    3 0 0
  1. Audi A4 long life service question
    By zebedoo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-08-2011, 07:13 PM
  2. whats the deal with fixed service & long life?
    By bmhill in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-08-2011, 12:14 PM
  3. Audi A4 1.9TDI Long Life Service which Oil to use?
    By kaleems in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-02-2009, 07:54 PM
  4. Question Long Life Service Indicator
    By blicky_1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-06-2008, 01:05 AM
  5. Long Life Service Indicator
    By gregk81 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-11-2007, 10:45 AM
