Thread: Console Bushes
Results 1 to 10 of 23
  1. Console Bushes
    Mar 2010
    High Wycombe UK
    My 56 plate 2.0TDI Sport SE estate is just in for routine (oil and pollen filter) service at 64K miles. Call from dealer saying front console bushes are split and need replacing. Cost £450 incl VAT. I bought car used from this dealer in March 2010 with 33K miles on it and a one yeaer VW used vehicle warranty. Car has full VW service history so far but this is a lot of money to pay out. :-( I understand that the console bushes are relatively inexpensive compared to the fitted cost and reading other posts I see that Powerflex bushes are better. I am a reasonably competent mechanic with a pretty full range of tools. Questions: 1) How difficult it is to replace these bushes, 2) Where might I find instructions? 3) I have seen that disturbed nuts and bolts must be replaced - is this correct?
    Thanks very much.
  2. Re: Console Bushes
    1840 Post(s)
    Yes the fasteners must be replaced. From VW the bush comes as a complete bracket 3C0 199 231 D at £53.47 each.
    http://www.candrenterprises.co.uk/sh...h-vw-06-1.html
    http://www.candrenterprises.co.uk/shop/superpro-uprated-suspension-bushes-vw-2005-2010-6.html
    The mount is easy to remove but really you should use an alignment pin, VW tool T10096 so maintaining the suspension alignment.
  3. Re: Console Bushes
    Mar 2010
    High Wycombe UK
    Thank-you Crasher for this helpful information. I found the T10096 pins at Laser tools but it is for a set of 4. This perhaps suggests that the whole subframe needs to be loosened when changing the bushes? Or are the bolts holding the console bush bracket the same ones that hold the subframe in place in that corner? Is the T10096 pin left in place when the job is finished or do you remove it? Thanks. I'm basically trying to make sure I don't get into a job I can't finish properly and trying to work out how difficult it is and what the bits will cost me. Do you know if the VW console bush price includes the replacement bolts?The VW dealer told me they have 2.2 hrs time chargeable for the job but rarely get it done in less than 3 hours.
  4. Re: Console Bushes
    1840 Post(s)
    You need a set of four pins IF you are dropping the whole subframe down, only one for a single consul removal. You insert the T10096, tighten it up and then remove the other two bolts, the bush aligns itself in the consuls bolt hole which can be perfectly aligned with the thread or offset to a degree, this means that when you put the consul back, it is fitted in the same place as it was originally. The VAG price is consul only, it is not a kit. I can do one consul in less than an hour if using a new standard consul, removing a VW bush and fitting a Powerflex adds quite a lot of time cutting the old bush out but fitting the new Powerflex is very easy, the Superpro is a little more involved as it is steel sleeved.
  5. Re: Console Bushes
    Mar 2010
    High Wycombe UK
    Thanks Crasher. Does your business also supply the T10096 pins? It seems I would only need 1 to do the bushes one side at a time. or I guess I could make one from an M12 bolt with the head suitably tapered and with a smaller hex welded on to screw it in?
  6. Re: Console Bushes
    1840 Post(s)
    You can order VAG tools from here tools.equipment@vwg.co.uk
  7. Re: Console Bushes
    Nov 2019
    UAE
    Hi carsher
    Do i have to replace bolts with original new bolts or specific ones has special features?
  8. Re: Console Bushes
    1840 Post(s)
    Almost every fastener on a modern VAG vehicle is a one time on Torque To Yield (TTY) and special purpose in their deign and tensile strength (usually 10.9) and anti corrosion tread as many go into aluminum, I know rust isn't an issue for you but it is for us, plus most have built in washers, replace them with generic ones and you may get away with it... you may not.
  9. Re: Console Bushes
    Feb 2020
    Bradford
    40 Post(s)
    Much of this vag corrosion would be global due to the metals used. Working on my golf recently rear control arm bushes were welded to its bolt (by
    dissimilar metal corrosion) and so was the aluminium handbrake rivets which go into the trailing arm. This type of corrosion happens when there is a direct connection between dissimilar metals
    Hence since the front subframe is some sort of aluminium alloy I would rather reuse old bolts rather than use unknown steel bolts.
    Re using these tty bolts is a controversial but common practice
  10. Re: Console Bushes
    Jul 2019
    Oxford
    I have been replacing my console bushes on a Touran. one of the bolts sheared off. I gather the is quite common. Trying to remove the sub frame part that the bolt is in. All bolts out but it is moving but stuck. Do I have to jack up the suspension strut the release the sub frame (console)?
  1. rubber console bushes
    By shahid1973 in forum Bora - 1998 - 2005
    Last Post: 27-02-2011, 01:12 AM
  2. How To centre console
    By passat tdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2011, 07:14 PM
  3. 47K "Console bushes"
    By simonarius in forum Golf MK5 - 2004 - 2009
    Last Post: 28-08-2008, 09:51 PM
  4. centre console
    By sbt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-07-2008, 08:43 PM
  5. Question centre console
    By tam64 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-06-2008, 10:06 AM
