Thread: Crankshaft Position Sensor Location (Error code P0322)
  1. Crankshaft Position Sensor Location (Error code P0322)
    Sep 2011
    Windsor, UK
    I have a 2000 VW Polo 1.4 Petrol engine, engine code AUD which has intermittently started producing error code P0322 – Ignition/Dist Engine Speed Input Cct No Signal and then dropping to limp home mode.
    I believe this fault points to the Crankshaft Position Sensor, but I have no idea where it is on this engine.
    Can anyone give me a pointer as to where I can find it so that it can be replaced
  2. Re: Crankshaft Position Sensor Location (Error code P0322)
    Sep 2011
    Windsor, UK
    Can anyone help, I'm struggling to find an answer to this problem
    Quote Originally Posted by Harv91 View Post
  3. Re: Crankshaft Position Sensor Location (Error code P0322)
    Apr 2012
    Wakefield, West Yorkshire
    did you ever get this resolved? I too am having problems with my Polo. I have had it code read & it comes back with Engine Speed Sensor (17606 PO322).
    Andrew
  4. Re: Crankshaft Position Sensor Location (Error code P0322)
    Sep 2011
    Windsor, UK
    Quote Originally Posted by andrew_beck View Post
    Andrew
    Yes, I did resolve it. I finally tracked down the sensor which is positioned in the most inaccesible place imaginable. It is located at the bottom rear of the engine between the starter motor and the engine block, at the right hand end if you're looking from the front of the car. It is necessary to remove the starter motor first (working from underneath the car) and then you can reach the sensor, which only has one fixing screw so is easy once you get to it.
    One other challenge is to actually identify the sensor you need as a replacement, it seems there are quite a few variants so its probably best to go to a VW garage rather than replace with a third party equivalent.
    Hope this helps & good luck
  1. Audi S4 Engine code problem, Crankshaft sensor
    By Audi_S4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2010, 07:28 PM
  2. where is crankshaft position sensor?
    By lpg boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-09-2010, 05:53 PM
  3. Please Help A4 20v turbo Camshaft Position Sensor error P0343
    By Matty Jones in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2010, 03:03 PM
  4. crankshaft position sensor location
    By collym3 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-04-2010, 01:32 PM
  5. camshaft position sensor error
    By glen70 in forum Touran - Sharan - Caravelle
    Last Post: 14-10-2009, 01:31 AM
