Thread: TDi warm start problem fixed!
  1. TDi warm start problem fixed!
    Jun 2010
    Redhill, UK
    I have had a TDi warm start problem for a while, as detailed in this thread:
    https://www.vwaudiforum.co.uk/forum/s...start-problems
    after a year or so of annoyance with the problem, I took the car to Tutt's to get it looked at
    invoice says:
    - No faults stored on ECU (which tallies with what I found with my mate's VAG-COM cable)
    - Engine Management fuses all okay
    - Main relay manufactured in Tunisia, known to be problematic, replace relay
    they replaced the following relay:
    part #: 1J0906381A
    £14 for the part, some labour, but all sorted now, finally
    hope this is of some use to someone with the same issue
    Andy
  2. Re: TDi warm start problem fixed!
    Jun 2013
    worksop
    I have the same warm start issue, starts first time when cold but a short or long journey and it churns away for 5 secs before starting
    Golf mk5 04 reg 1.9 TDi
    AM i right in thinking if it was the mass air flow meter or enging temp sensor then it would show up on the fault codes ?
    because i have no fault codes
    so wondering if the relay will fix the issue ?
    Number 109 ECU Relay / Fuel Pump VW Audi Seat Skoda Diesel Meyle Germany | eBay
    Thanks John
  3. Re: TDi warm start problem fixed!
    Jun 2013
    worksop
    Also where will i find this relay please ?
  4. Re: TDi warm start problem fixed!
    May 2014
    penzance
    Hi Johnb48 did you find a relay and try it... and did it fix the problem?
  5. Re: TDi warm start problem fixed!
    Jun 2013
    worksop
    Quote Originally Posted by oggiepirate View Post
    I didn't try the relay because when I swapped my battery for a 2nd hand one it worked
    Weird that it started ok when engine cold but not enough power in the battery to warm start but it was a cheap fix :-)
  6. Re: TDi warm start problem fixed!
    Aug 2014
    glasgow
    john was battery before replacing still reading 12v thanks
  7. Re: TDi warm start problem fixed!
    Sep 2017
    Grimsby
    Quote Originally Posted by andyh12345 View Post
    diesel warm start problems
    invoice says:
    part #: 1J0906381A
    Andy
    I have got relay were do I put it mate please help
  1. Question VW Golf 2004 TDi 1.9SE Warm Start Problem.
    By IMK1230 in forum Golf MK5 - 2004 - 2009
    Last Post: 27-11-2010, 02:34 PM
  2. 2006 Jetta 1.9 TDI Warm Start Problem
    By MrXee in forum Jetta MK3 - 2005 - 2013
    Last Post: 19-08-2010, 07:44 PM
  3. 2.5 TDI warm start problem, white smoke
    By moosetication in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-01-2009, 08:14 PM
  4. Sharan TDI Warm Start Problem
    By keithm in forum Touran - Sharan - Caravelle
    Last Post: 27-04-2008, 02:12 PM
  5. Sharan TDI Warm start problem
    By timshaw in forum Touran - Sharan - Caravelle
    Last Post: 02-02-2007, 10:18 AM
