Thread: Coming home/ Leaving home lights
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Coming home/ Leaving home lights
    Manchester, UK
    Quote Originally Posted by VeDubDan View Post
    Fingers, can I just confirm. You take the keys out, out of the car, close the door, and the lights remain on until to actually lock it?
    My lights turn straight off as soon as I take the key out of the ignition. As soon as it's pulled out, lights off.
    YES!!! Thats exactly what they do, stay lit until i lock then they go out. I know the exact spot now where the key will still lock at a distance.
    As soon as i unlock front, rear and mirror puddles light up for 20 seconds (changed from std 10 secs)
    Not played with the stalk yet to see if that changes anything.
    You have to leave your light switch in Auto also i think.
    Phil
    2012 - 2.0 TDI 140 Match Manual Golf - Steel Grey
    2002 - BMW 316ti Manual with all the toys
    2011 - 2.0 TDI SE Manual B7 Passat - Candy White Now GONE :-(
  2. Re: Coming home/ Leaving home lights
    Nov 2008
    Another way to switch the lights on for "coming home" . . . onve you have pushed the ignition off and pulled your fob out, press the unlock key on the fob and all the lights will come on . . .a better way then pulling the stalk cos you can see the flash when you do that . . . . bad news is the lights still go out when you lock the car.
    Hope this helps :-)
  3. Re: Coming home/ Leaving home lights
    Nov 2010
    Bolton
    I can confirm pulling the full beam on for a second does make the lights come on when opening the drivers door. Not ideal, but it works
    Passat B7 - White - Sport - 140PS BMT.
  4. Re: Coming home/ Leaving home lights
    Jul 2011
    Warks
    Here's what mind does;
    'Coming home' mode...
    Light sw on 'Auto'
    Turn off ignition and remove key,
    'flash' main beam,
    lights come on for preset time (as set in the MFD),
    lock car - lights stay on for remainder of duration.
    'Leaving home' mode...
    Light sw on 'auto'
    unlock car,
    Light sw on 'OFF' nothing works.
    Passat Sport Est 140, Polo, A3, Karmann Ghia, MG TF, Lotus Elise.
  1. Coming/Leaving home lights
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 03:28 AM
  2. Replies: 21
    Last Post: 13-09-2009, 07:31 PM
  3. Leaving home/coming home lights
    By paul b in forum VCDS - General Questions
    Last Post: 06-10-2008, 05:36 PM
  4. VW steering wheel & coming/leaving home lights...
    By ads_ali in forum Golf MK5 - 2004 - 2009
    Last Post: 30-03-2008, 04:49 PM
  5. Automatic Headlights with coming home /leaving home facility
    By TonyS in forum Chat - Anything with wheels
    Last Post: 25-06-2007, 03:44 PM
