Thread: Leak from blower fan? see pics
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Leak from blower fan? see pics
    #11
    Oct 2007
    Remove glove box, lower “A”-pillar trim and mat on passenger's side Carefully fold back floor covering. Unfasten clip Pull condensate drain hose with condensate drain valve out of floor panel.Remove condensate drain valve check and clean
  2. Unhappy Re: Leak from blower fan? see pics
    #12
    Mar 2009
    Quote Originally Posted by kenney View Post
    Hey, Followed these instructions and there is nothing on the passenger floor panel that looks like a drain valve. Any other ideas?
  3. Re: Leak from blower fan? see pics
    #13
    Oct 2017
    BOLTON
    Hi davee1987. Have you managed to sort the leak from blower fan? I'm having the same problem.
  4. Re: Leak from blower fan? see pics
    #14
    Mar 2009
    Yes. I lifted the carpet and there was a rubber drainage tube which was blocked, I unblocked it and and problem was sorted , quite an easy fix
  5. Re: Leak from blower fan? see pics
    #15
    Oct 2017
    BOLTON
    Quote Originally Posted by davee1987 View Post
    Thanks for the reply. Is the drain tube you are talking about the AC condensate drain hose? Because the leak only occurs after rainfall and even if AC is off.
    About where behind the carpet is the drain tube you mentioned?
  6. Re: Leak from blower fan? see pics
    #16
    Mar 2009
    Quote Originally Posted by Khan2468 View Post
    Yes mine was the AC drain hose, it is located under the passenger Floor well carpet(under the glovebox)... sounds like your leak is caused from a different issue
  7. Re: Leak from blower fan? see pics
    #17
    Oct 2017
    BOLTON
    Thanks for the advise davee1987. I cleared the hose that is under the carpet (red circle on picture below ) and it hasn't leaked since. Wasn't expecting to solve the issue as the leak was only after rainfall.
  1. Heater Fan Blower
    By Fred Thornton in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-02-2011, 12:37 PM
  2. Fan / Heater Blower
    By stua4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-10-2010, 07:10 PM
  3. Climatronic Blower Fan
    By limawhiskey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-03-2008, 09:49 PM
  4. Blower fan
    By ledge26 in forum Passat - Archive Topics
    Last Post: 14-11-2006, 12:45 PM
  5. Noisy blower fan
    By Jimchoc in forum Passat - Archive Topics
    Last Post: 29-08-2006, 06:33 PM
