Thread: Cordoba handbrake travel
  1. Cordoba handbrake travel
    Nov 2010
    Llandrindod Wells Wales
    I am puzzling over why I have a 1998 Cordoba with long cable movement on the RH, and so much less on the LH. I cannot see any obvious shortcoming with the RH adjuster. Anybody?
  2. Re: Cordoba handbrake travel
    Blairgowrie
    on the backplate behind the drum there should be a rubber grommet the adjuster is behind that a flat head screw driver should do it. If its discs the piston could be seized a bit, its pads out and turn anti clockwise whilst pulling then wind them back in and replace it may free it up
  3. Re: Cordoba handbrake travel
    Nov 2010
    I suppose I should have stated it is a drum brake. It does not have a wheel and threaded bar adjuster set-up, it is a wedge pulled by a spring. I cannot recall ever seeing anything like it before!
  4. Re: Cordoba handbrake travel
    Nov 2010
    ...... and the 'teeth' on the shoes were corroded, and worn 'away' on the wedge!
  5. Re: Cordoba handbrake travel
    Blairgowrie
    so is that you diagnosed the problem? is it sorted?
  6. Re: Cordoba handbrake travel
    Nov 2010
    Final proof comes tomorrow when new shoes and wedges should be fitted.
  1. 98 Polo 1.0 - Handbrake travel / rear brake efficency
    By petitpal in forum Polo - Derby - Lupo - Fox
    Last Post: 14-02-2011, 07:27 AM
  2. Question European Travel?
    By Autobulbs in forum Chat - Anything with wheels
    Last Post: 15-05-2009, 02:33 PM
  3. Midlanders And Anyone Who Wants To Travel!!!
    By euroslap in forum Chat - Anything with wheels
    Last Post: 27-11-2008, 01:40 AM
  4. Handbrake "No reserve travel"
    By jemthetaxi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2008, 09:00 AM
  5. Any Travel Agents on here?
    By Eshrules in forum Chat - Completely Off Topic
    Last Post: 21-01-2008, 12:29 AM
