Thread: Auxilary heater relay J8
  1. Auxilary heater relay J8
    Feb 2007
    Does anyone have the part number for the auxilary heater relay (J8 in the wiring diagram), located in the middle (position 2) of the small relay carrier behind the dashboard?
    Also, does anyone know where I can get the crimp terminals for the relays and fuse box (or the part numbers if available from Audi/VW)?
  2. Re: Auxilary heater relay J8
    This sounds as if you have retro fitted an Aucillary Heater. That was a big job. Perhaps you would like to explain. I'm afaid I can not help with the part number perhaps Crasher can help. Regards Peter
  3. Re: Auxilary heater relay J8
    Feb 2007
    Hi Peter,
    thanks for the reply, I am preparing for the big job!!
    The relay is 5 terminal change-over, 30amp if that helps narrow it down?
    I think I now have some information on the crimp contacts, which may be of use to others, is it ok to post a link to another forum which gives a list of terminals with part numbers (and also an alternative non-VAG source) (I don't want to infringe any posting rules)?
  1. Please Help touran auxilary heater
    By tractor fixer in forum Touran - Sharan - Caravelle
    Last Post: 06-01-2011, 08:54 PM
  2. Auxilary Heater
    By rally5 in forum Touareg
    Last Post: 30-10-2009, 01:12 AM
  3. AUX HEATER RELAY (where?)
    By sharalaxy in forum Touran - Sharan - Caravelle
    Last Post: 19-12-2008, 12:33 AM
  4. Sharan Rear Screen Heater Relay
    By digdig in forum Touran - Sharan - Caravelle
    Last Post: 12-04-2008, 05:45 PM
  5. Auxilary heating
    By D'Squared in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2008, 10:54 PM
