Thread: Weird aircon issue
Results 1 to 10 of 10
  1. Weird aircon issue
    Mar 2009
    London
    I've been searching the threads here and quite a few people have problems where hot/cold air only blows out of one of the vents or the temperature doesn't change when switching between low and high (ie, the aircon blows hot air). Both are usually caused by a dodgy or sticking motor.
    Got a similar problem in mine which is slightly different. I get icy cold air from both the drivers side vents but only moderately cold air from the passenger side. The airflow seems a bit weaker on the passenger side too. Is this likely to be the motors as well or do I just need to get the aircon serviced and topped up?
    If it's just the gas that needs topping up, I would have expected the aircon not to be ice cold from any of the vents
    04 A4 1.8
    T S-Line Multitronic (190bhp)
    Misano Red - Factory RS6 18" Alloys - Rear Folding Seats - Park Distance Control - Private Number Plate
  2. Re: Weird aircon issue
    Sep 2008
    chester
    17 Post(s)
    You've got a sticking flap motor,take the glovebox out and check the operation.If you've got icy air coming out the drivers side the systems working ok.
  3. Re: Weird aircon issue
    Mar 2009
    London
    Thanks mate, will try to take a look this weekend and report back
    Have done a search for threads on how to remove the glovebox but can't find any Does the side panel also need to come off?
    04 A4 1.8
  4. Re: Weird aircon issue
    Sep 2008
    chester
    17 Post(s)
    Open the lid there's 3 along the top, end panel off the one like the fuse panel on the other side,theres one there,2 on the bottom,and if you've got a cd unit remove it and there's one above it,
  5. Re: Weird aircon issue
    Mar 2009
    London
    Well I couldn't seem to find those screw holes, think I need to go back in with a torch after a trip to SpecSavers
    04 A4 1.8
  6. Re: Weird aircon issue
    Sep 2008
    chester
    17 Post(s)
    Lower the lid and there's three holes in the top the bolts are recessed in the holes.
  7. Re: Weird aircon issue
    Mar 2009
    London
    Removed ther glovebox and can see the green and red levers moving when I change the aircon flow (and also on start/stop engine). Still feel the airflow is not as cold from the centre vents though.
    04 A4 1.8
  8. Re: Weird aircon issue
    Sep 2008
    chester
    17 Post(s)
    The green is the screen defrost,the red is the temp for the passenger side so make sure it shuts off completely if set to cold,the centre vents is a different motor according to my diagram its V70,whats the airflow like when on full on the screen?,just to eliminate the blower.
  9. Re: Weird aircon issue
    Mar 2009
    London
    Good idea, let me check the aircon on full on the screen.
    04 A4 1.8
  10. Re: Weird aircon issue
    Sep 2008
    chester
    17 Post(s)
    The motor that controls the centre flaps is the one you can see in the photo with bosch on it,remove the 3 bolts and operate by hand see if that improves
  1. Aircon issue
    By Eugheugh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-08-2011, 04:26 PM
  2. Question Weird Aircon Behaviour. . . .
    By ::SPG:: in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-09-2010, 11:48 PM
  3. Weird wing mirror issue.
    By elvismiggell in forum Chat - Anything with wheels
    Last Post: 12-04-2010, 10:00 AM
  4. Weird Multitronic issue
    By Seanious in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-11-2009, 04:57 PM
  5. Aircon issue
    By nickynibbles in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2007, 03:24 PM
