Thread: Differences between 2.0 TDI 143 and 170?
  1. Differences between 2.0 TDI 143 and 170?
    Jul 2011
    Marbella
    Does anyone know what the exact differences between these 2 engines are?
    Different engine management? Turbo? other parts?
    2010 A4 B8 Avant S-line +
  2. Re: Differences between 2.0 TDI 143 and 170?
    Jul 2011
    Marbella
    Just found some threads that indicate that it might have a bigger turbo, different map, and injectors, can anyone confirm this?
  3. Re: Differences between 2.0 TDI 143 and 170?
    Nov 2008
    Suffolk
    its definitely something along those lines otherwise superchips would be able to map a 143 to the same as they can map a 170.
    2018 Amarok V6
  4. Re: Differences between 2.0 TDI 143 and 170?
    Jul 2011
    Marbella
    Would love to know to exactly what it is, to see whats possible.
  5. Re: Differences between 2.0 TDI 143 and 170?
    Nov 2008
    Suffolk
    from
    http://www.audi-sport.net/vb/new-a3-...ifference.html
    There is not much difference in hardware between the 140 and 170.
    According to ETKA, the CR-170 has different part numbers for the following.
    Turbo
    2 different intercooler boost pipes
    Flywheel
    DPF
    EGR cooler gasket
    Not sure if the same applies to the older PD unit.
    Can't remember if the 170 has larger front brakes, will check later this evening.
    2018 Amarok V6
  6. Re: Differences between 2.0 TDI 143 and 170?
    Jul 2011
    Marbella
    Quote Originally Posted by jakerade View Post
    from
    Turbo
    Flywheel
    DPF
    EGR cooler gasket
    Thanks for that, assume the brakes will be the same as it does a good job of stopping (atleast my 143 does).
  1. Question What's the difference between 143 and 170 bhp 2.0 TDI engines
    By Zonked223 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-06-2015, 01:50 AM
  2. 2.0 TDI 143/170 Differences ???
    By GrantD27 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-03-2010, 07:12 PM
  3. Engine differences between the 140 and 170 TDI
    By Japtastic in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-03-2010, 12:12 AM
  4. 143 v 170 TDI
    By pitch3110 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-06-2009, 09:03 PM
  5. 170 and 140 TDi visual differences
    By ttothec in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-05-2008, 02:01 PM
