Thread: audi A4 avant accelerator pedal problem
Results 1 to 10 of 11
  1. audi A4 avant accelerator pedal problem
    Aug 2011
    northeast
    Hi all, Please help! I recently bought an 04 Audi A4 Avant 1.9 TDI it broke down soon after, first fault was displayed as brake pedal position sensor, I renewed this and had the fault cleared. It was fine for approx a week and it happened again the fault this time was the accelerator pedal position sensor, again I renewed the full pedal unit and cleared the fault. Again it was fine for a couple of weeks then broke down again with the same accelerator pedal position sensor. After reading some of the comments on the forum I have checked the ECU and it appears that someone has had the ECU cover off without removing the rear bolt and smashed the cover. Can anyone tell me, is it likely to be water getting in thats causing the problems? If I renew the cover will this be enough or is there a specific area or plug I need to check for damage? Thanks.
  2. Re: audi A4 avant accelerator pedal problem
    134 Post(s)
    2009 Post(s)
    Yes, water in the plugs, very very common. If you look closely you will see one of the pins in the orange plug is heavily corroded.
    2 1 0
  3. Re: audi A4 avant accelerator pedal problem
    Aug 2011
    northeast
    Hi Crasher, I have just stripped it down only to find that my 2004 a4 doesn't have that orange plug, and the others look fine, do you have any other suggestions please? Thankstunnel 047.jpg
  4. Re: audi A4 avant accelerator pedal problem
    134 Post(s)
    2009 Post(s)
    All the throttle pedal signals go though plug T17e (Pins 1 to 6) and this is the white plug, the brake and clutch pedal switch wiring also goes through this plug. Check the terminals (12, 50, 52, 63, 69 and 70) at the ECU plugs to make sure they are not corroded.
  5. Re: audi A4 avant accelerator pedal problem
    Aug 2011
    northeast
    thanks I will give that ago in the morning
  6. Re: audi A4 avant accelerator pedal problem
    Aug 2011
    northeast
    after all it seems to be just the water getting in through the cracked ecu cover, I have checked all the plugs and wires for corrosion all seems ok, I have put it all back together
    and it has cleared the fault and drives perfect (for how long???). Thanks for all your help
  7. Re: audi A4 avant accelerator pedal problem
    Dec 2018
    London
    Hello mate I have same problem but I can’t find them plugs can u help e with that please ?
  8. Re: audi A4 avant accelerator pedal problem
    Dec 2018
    London
    Can anybody help me cuz I don’t know where this pins are located pls
  9. Re: audi A4 avant accelerator pedal problem
    134 Post(s)
    2009 Post(s)
    You have to remove the ECU box in the plenum chamber.
  10. Re: audi A4 avant accelerator pedal problem
    Nov 2014
    Miri1991....you’ll have to remove the wiper blades and the plastic scuttle panel which hides the battery and wiper motor. The ECU is located under there. I had the same problem a little while ago and traced it back to the seal around the ECU cover. It always happened when it had been raining hard, the water gets in and drops down the wiring harness to the pedals.
    Hope this helps.
  1. Please Help Slight vibrations from accelerator pedal on Audi A4 B7 model
    By vincentlv in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-09-2010, 04:01 PM
  2. 1994 A4 Avant Accelerator pedal broken
    By BTB 500 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-11-2009, 12:07 PM
  3. Accelerator Pedal
    By nicky900 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-12-2008, 09:03 PM
  4. Accelerator Pedal
    By JoGibson in forum Golf MK4 - 1999 - 2004
    Last Post: 19-10-2008, 03:16 PM
  5. Please Help Accelerator pedal
    By firestarter in forum 80 - 90
    Last Post: 27-09-2008, 11:04 PM
