Thread: 1.9tdi which engine oil to use - confused
Results 1 to 10 of 13
  1. 1.9tdi which engine oil to use - confused
    Aug 2009
    largs scotland
    I am very uncertain about which oil I should use for an oil change on my 1.9tdi. The manual says it should conform to vw500 or vw 505. Millers recommend these :
    XF Longlife 5w30
    XFE-PD 5w40
    Trident Longlife 5w30
    or what about these :
    http://www.ppcgb.com/Audi/A4-B7-2WD-...mo1184-ct1190/
  2. Re: 1.9tdi which engine oil to use - confused
    Mar 2007
    9 Post(s)
    hi mate just do what i do go to audi or vw main dealer and buy some quantum longlife 3 its about 35.00 quid for 5 litres it covers all specs from 504,00 to 507.00 it is meant for longlife servicing but you can change it as often as you like i change mine about every 8000 miles it is what audi would use if servicing your car . and while your there get yourself a genuine oil filter hope this helps
  3. Re: 1.9tdi which engine oil to use - confused
    somerset
    8 Post(s)
    Yes, i totally agree Quantum longlife 3 and genuine filter. I have a TPS account and oil is £25 ish and filter £5. Quantum is re-labeled castrol edge oil anyway. I always change mine every 6K miles, but it's the 1.8T which is prone to sludge build up and blocking the oil pickup.
  4. Re: 1.9tdi which engine oil to use - confused
    Aug 2009
    largs scotland
    thanks for the advice, I have ordered the oil and filter.
  5. Re: 1.9tdi which engine oil to use - confused
    Aug 2009
    largs scotland
    Ok, oli change done and I have covered 900 miles. I have noticed a significant improvement in MPG, possibly in the order of 15%. The car was running some cheap halford semi synth before.
    Do you think this is a real improvement and has anyone else experienced this ?
  6. Re: 1.9tdi which engine oil to use - confused
    1840 Post(s)
    Quote Originally Posted by rhencullen1989 View Post
    If that is the case, why did the 205 litre barrel of Quantum Platinum I have just opened say BP on the label?
  7. Re: 1.9tdi which engine oil to use - confused
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    He who sells it to VW cheapest for the quarter eh
  8. Re: 1.9tdi which engine oil to use - confused
    Mar 2007
    9 Post(s)
    Quote Originally Posted by danclyon View Post
    hey. could enlighten us
  9. Re: 1.9tdi which engine oil to use - confused
    Jan 2014
    Glossop
    Just joined and saw this post whilst searching. Its probably say BP as both BP and Castrol are Burmah Castrol.Follow link below. Worked for Castrol years ago and pensions are through BP, same company, different labels.
    http://www.bp.com/en/global/corporat...and+lubricants
    Also notice that the Ford formula f oil is in the same bottle as Quantum oils and the Ford stuff is Castrol, says so on the label, lubricants UK who are BP/Castrol
  10. Re: 1.9tdi which engine oil to use - confused
    1840 Post(s)
    The new drum I have just had delivered says BP Europa Belgium on it.
  1. Confused about oil changes when buying used
    By SteveE in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-03-2010, 10:30 PM
  2. Replies: 3
    Last Post: 23-02-2010, 06:38 PM
  3. T4 1.9TDI Engine oil
    By dangerousdog in forum The Commercial Range
    Last Post: 22-10-2008, 12:04 PM
  4. Golf Match 1.9tdi - Engine Oil Change
    By oriondirect in forum Golf MK5 - 2004 - 2009
    Last Post: 18-06-2008, 09:12 PM
  5. engine oil for transporter t5 t28 1.9tdi
    By paul600rr in forum Archive posts
    Last Post: 26-12-2007, 04:16 PM
