Thread: heater blows cold on driver side but hot on passenger side.
  1. heater blows cold on driver side but hot on passenger side.
    Aug 2011
    Pudsey West yorkshire
    Temperature controls O.K on passenger side, but on drivers side is usually cold, but occasionally works O.K.
    I think I must have a sticking flap servo, but where is the motor located?
  2. Re: heater blows cold on driver side but hot on passenger side.
    Southern County Softy
    20 Post(s)
    Take off the lower dash panel on the drivers side, if its not that side then remove the glovebox.
    A4 2.5 tdi QS (mapped)
  3. Re: heater blows cold on driver side but hot on passenger side.
    Aug 2011
    Quote Originally Posted by kite View Post
    Thanks for the advice. Did as you suggested, & found yellow linkage that connects to motor has snapped off of ball-joint or whatever connects it to the motor.
    I guess I will need to take centre console & stereo etc out, to get any further.
  4. Re: heater blows cold on driver side but hot on passenger side.
    Jun 2008
    Western Europe
    The yellow arm is connected directly to the motor,so you need to buy the motor itself.It is held on by 3 bolt head screws,I think they are 8mm heads.It can
    be removed without taking out the centre console but its quite awkward.
  5. Re: heater blows cold on driver side but hot on passenger side.
    Sep 2008
    chester
    17 Post(s)
    It may not have snapped,have a look when you've got the motor off,exercise the lever by hand see if it operates,they should just click back in.
  6. Re: heater blows cold on driver side but hot on passenger side.
    Aug 2011
    Thanks lads.
    will attempt to remove motor. Do you know any contortionists who could give me a hand?
  1. Only passenger side blows hot air
    By sabikeuk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-08-2011, 06:45 PM
  2. One Side blows hot one cold!
    By Cellardwellers in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-10-2010, 09:56 PM
  3. Please Help Heater blowing cold air on one side hot on other
    By rushyo1 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-02-2010, 11:07 PM
  4. Drivers side heater/cooler only blows hot!
    By beddo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-04-2009, 09:57 AM
  5. Heater only blowing hot air on passenger side
    By stuartt0712 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2009, 08:16 PM
