Thread: which engine oil for short journeys
Results 1 to 10 of 10
  1. which engine oil for short journeys
    Mar 2007
    due an oil change on 1.8 petrol b5 x reg.
    can anyone advise on the better oil bearing in mind the wife works only 2 miles away so i imagine engine needs warming up rather quicker than normal . from what i can make out its 5 w30 ???
    cheers in advance.
  2. Re: which engine oil for short journeys
    1841 Post(s)
    Use Quantum Platinum, it is a 5w/40.
  3. Re: which engine oil for short journeys
    Mar 2007
    thanks for the reply,seems a cheap option as well
  4. Re: which engine oil for short journeys
    Mar 2007
    right , before i changed the oil i removed oil filler cap and noticed their is a layer of black film not thick at all.
    so before i change oil would a flush be reccomended or just make sure the engine is well warm before i drain the oil?
    thanks
  5. Re: which engine oil for short journeys
    Apr 2009
    Quote Originally Posted by barrymorri View Post
    Is this a black film of liquid oil, or caked-on carbon?
    If its black oil.... proceed as normal, with a warmish engine
    Regards
    Jim
    Still Crazy After All These Gears
  6. Re: which engine oil for short journeys
    Mar 2007
    possibly caked-on carbon as its a tacky, maybe oil change then repeat after 1000miles??
  7. Re: which engine oil for short journeys
    Apr 2009
    If you use a diesel spec oil for the 1000 miles it will help to clean-it-out gently
    Regards
    Jim
  8. Re: which engine oil for short journeys
    Mar 2007
    a big thanks for your replies , im planning on a 700 mile round trip next week so would it be a good idea to do 350mile straight run with the diesel oil? , sorry if it sounds dumb but what spec diesel oil would you recommend ?. presumable a more expensive one would just be a waste of good grade oil for a 1000 mile
  9. Re: which engine oil for short journeys
    Apr 2009
    Stick to the oil Crasher recommended above for both changes
    Regards
    Jim
  10. Re: which engine oil for short journeys
    Mar 2007
    am i right in thinking this should be in the £30 mark as i was just forced to pay £40 for 5L , did not have to buy i suppose but left it too late go elsewhere,that was at my local seat dealer.
  1. One of those journeys
    By fat controller in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-08-2011, 11:28 PM
  2. Please Help Short engine or whole assembly?
    By BobProperty in forum Golf MK3 - 1993 - 1999
    Last Post: 01-10-2010, 03:56 PM
  3. Question Loss of turbo early in journeys
    By mwhitehouse in forum Bora - 1998 - 2005
    Last Post: 23-01-2010, 07:08 PM
  4. Replies: 1
    Last Post: 07-07-2009, 10:48 AM
  5. 1.4 16v BCA engine needs new short motor
    By jazzman2007 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2009, 04:16 PM
