Thread: Horn?
  1. Horn?
    Aug 2010
    Slough Berks UK
    Out and about today horn stopped working
    Took lower drivers grill out found horn i take it theres only one?or is there another behind other grill other side
    Checked fuses ,It had blew
    Changed it but all i get is a click noise
    Seen them on ebay are they a quick swap
    or because of canbus do i need to fit a vw one
  2. Re: Horn?
    Norfolk
    Two horns one high one low. Power comes via relay. When you press the horn button, does the horn feed wire to each horn become live. Check between feed wire and a good earth. If the 12v feeds are ok then you need new VW horn (s)
  3. Re: Horn?
    Aug 2010
    Slough Berks UK
    Look at it today no horn
    Took one off and the other side works now?
    Though i would test it on a car battery a faint ding noise
    Went to gsf and bought a new one tested it on a car battery and it does the same as the one ive just taken off strange?
  4. Re: Horn?
    Norfolk
    Swap the good car horn to the bad car horn side and see if it still works. If it does, you know the wiring is ok. The new GSF horn may be faulty. Did you connect it the right way round.
  1. Horn
    By russellm72 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2010, 07:52 PM
  2. Car Horn
    By djah in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-12-2009, 12:13 PM
  3. Horn on my 97 A6
    By luvmyaudi in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-02-2008, 11:32 PM
  4. Horn
    By greaseball in forum Toledo
    Last Post: 28-11-2007, 10:24 AM
  5. Horn
    By greaseball in forum Altea
    Last Post: 19-10-2007, 07:47 PM
