Thread: water leak rear passenger door!!!!!!
  1. water leak rear passenger door!!!!!!
    hi guys what could be causing this ? seals? maybe adjust door lock? any ideas would be much appreciated....
  2. Re: water leak rear passenger door!!!!!!
    Aug 2007
    The first thing to do is to check the drain holes in the bottom of the door, if these are blocked, water that goes down past the window seal will have to drain out into the car.
  3. Re: water leak rear passenger door!!!!!!
    Sep 2009
    Lincoln, England
    6 Post(s)
    More than likely the seal has failed from the metal inner panel to the door. Either renew the seal, or do what i did and loosen the panel off, dry, and then seal with silicone sealant. Then the water will go out of the drains, and not the most easiest route.
    Hope this helps,
    Daz
  4. Re: water leak rear passenger door!!!!!!
    thanks for the replies guys, ive been so busy with work and other commitments that i havent had the time to look at it..will do this weekend and let you know how i get on..wish me luck cheers
  5. Re: water leak rear passenger door!!!!!!
    GRAHAM.C Guest
    Had the same problem with mine last year when ever it rained or washed the car.Removed bolts from regulator panel applied silicon sealant tightened bolts,job done,and problem fixed,(simple'sss)
  1. Important Water Leak in Passenger Rear Footwell
    By Hodgy in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2014, 07:34 PM
  2. Water leak - rear passenger side
    By simonhaslam in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-01-2010, 06:40 PM
  3. water leak from top of passenger door(wing mirror)
    By justin31 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2009, 12:04 AM
  4. water collecting on rear passenger door sill
    By kennyboy in forum Passat CC
    Last Post: 25-11-2009, 10:22 AM
  5. Rear Wiper Water Leak in Passenger Footwell
    By mike_watts in forum Alhambra
    Last Post: 24-02-2008, 11:49 PM
