Thread: oil sludge in expansion tank
  1. oil sludge in expansion tank
    Dec 2007
    Initial thoughts are head gasket. head was overhauled including skim 40k ago, it was a payen set cardboardy with steel flame rings. Could this be u/s already?
    As the engine oil has no evidence of contammination, could the oil be creeping in through a flaw in the oil filter cooling base, are these prone to failure or am I being wildly optimistic as it would be a lot easier to sort out?
    The engine is otherwise running, pulling and idling just as well as it always did.
    The car is a 1995 GL estate with a 2E engine
  2. Re: oil sludge in expansion tank
    Oct 2007
    most likely the oil cooler
  3. Re: oil sludge in expansion tank
    Jun 2007
    Probabley the oil cooler. Disconnect the two water pipes and joint them together with a piece of copper pipe. Run the engine and await oil to seep out of the cooler. Regards Peter
  1. Oil in expansion tank
    By joeynicholls in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-05-2011, 09:48 AM
  2. T5 2.5 tdi oil in expansion tank????
    By anilkumar in forum The Commercial Range
    Last Post: 16-11-2010, 05:52 PM
  3. sludge in filler tank.
    By yellowcan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2009, 10:32 PM
  4. Question Expansion tank full of oil! Is it what I think it is?
    By gkoshra in forum Golf MK4 - 1999 - 2004
    Last Post: 10-03-2009, 09:56 AM
  5. Oil in Expansion Tank - PD150
    By KashBash in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2008, 06:42 PM
