Thread: Turbo police siren noise - When to replace the Turbo.
Results 1 to 10 of 10
  1. Turbo police siren noise - When to replace the Turbo.
    Jul 2008
    High Peak, Derbyshire.
    Sorry to raise this issue again but I have struggled to find a sensible answer to this question.
    I have had the infamous police siren noise for 3 years. I have had advice that it is normal and other advise that it is on its way out.
    I am satisfied from extensive research including from a turbo specialist THAT NO TURBO SHOULD MAKE THIS NOISE.
    Drove to Liverpool yesterday - 40 odd miles. Again completely silent on the motorway. On the side roads, at low speeds, the noise is obtrusive, there is no other word to describe it and it is worse, much worse, when the engine is hot after a longish run. At low speeds it pretty much whines all the time - at higher speeds it goes away.
    So the issue is this.
    When do I replace the turbo?
  2. Re: Turbo police siren noise - When to replace the Turbo.
    1834 Post(s)
    It is up to you, have it rebuilt now and it will cost you £250 ish less than if you have it rebuilt when it goes pop.
  3. Re: Turbo police siren noise - When to replace the Turbo.
    Jul 2008
    Thanks mate. Would you recommend having the turbo rebuilt or get a new one?
  4. Re: Turbo police siren noise - When to replace the Turbo.
    1834 Post(s)
    I fit rebuilt units; the people I use are very trustworthy and reasonable.
  5. Re: Turbo police siren noise - When to replace the Turbo.
    Sep 2008
    hi crasher, you have confused me now because on many of your previous replys to threads on this subject ,you have said you only fit new genuine turbos because of the warrenty that comes with it,so are you now saying that a rebuilt turbo woud be fine?
  6. Re: Turbo police siren noise - When to replace the Turbo.
    1834 Post(s)
    This must be my feminine side coming out here (!), the prerogative to change ones mind at will whenever I feel like it! I used to insist on nothing but a genuine turbo but I had to come down to earth and respect peoples pockets in these admittedly straitened times and I have a great company near me who do a smashing job of rebuilding turbos. OK, you don’t get a 24 month labour inclusive warranty but they have been 95% reliable for me and it means I can do the complete job for a couple of hundred pounds less than the price of a VAG exchange turbo in the box, never mind fitted.
  7. Re: Turbo police siren noise - When to replace the Turbo.
    Sep 2008
    ok good answer crasher, i cant argue with that one,is there a posibility of damage to the engine should the turbo blow?
  8. Re: Turbo police siren noise - When to replace the Turbo.
    1834 Post(s)
    Yes, very much so.
  9. Re: Turbo police siren noise - When to replace the Turbo.
    Nov 2010
    dublin ireland
    My turbo lasted about 2 years with the whining and i had a heavy foot, i opted to go for a reconditioned unit which comes with a 1 year warranty, all in all it cost me €500 with sending the knackered one back to the uk aswell, along with the turbo going it dumped oil into the catalytic converter, so i just cut it out and i have a few more horses.
  10. Re: Turbo police siren noise - When to replace the Turbo.
    Mar 2009
    staffs
    i had my turbo (jetta 1.9tdi engine code bxe) replaced at the dealer under warranty coming up to 2 years ago,21k miles later its started doing the siren noise again only when its cold after 5mins it goes. this is how mine started the 1st time round in the end even when id been driving for 30 odd miles it would not go away.it took nearly 6 trips to the dealer to replace it.each time the mecanhic would say....i cant hear it sir!!!
  1. Question Siren noise - turbo problem??
    By vdub2 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-10-2014, 08:57 PM
  2. Question Police siren noise
    By 19wayne68 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-02-2011, 07:31 PM
  3. Question turbo sounds like a police siren!!!!
    By nc7503 in forum Golf MK5 - 2004 - 2009
    Last Post: 29-09-2009, 08:50 AM
  4. low pitch police siren noise
    By repoker23 in forum Touran - Sharan - Caravelle
    Last Post: 12-05-2009, 01:46 PM
  5. Replace turbo :(
    By Rob-S in forum TT - 8N Forum - 1998 - 2006
    Last Post: 24-06-2008, 01:37 PM
