Thread: Injector Failures - Possible recall
Page 53 of 67 FirstFirst ... 343515253545563 ... LastLast
Results 521 to 530 of 661
  1. Re: Injector Failures - Possible recall
    May 2007
    Thanks to all for this very informative thread, just got car back from VW with injectors changed all changed FOC, they stated that although this was a exchange there was no warranty, i then informed them of VOSA's letter and legality of consumer rights, i stood firm and although the service manager would not verbally give me a guarantee he knew that i was covered.
    Car now driving a lot smoother in mid range and have seen slight improvement in MPG
  2. Re: Injector Failures - Possible recall
    Ok, next step.
    I called VW UK today and told them of the previous cost to me last year for an injector failure. (£855.44)
    The gentleman on the phone started a new case, and has asked me to send him the relavent documents and seemed very apologetic etc.
    They hope to sort this within 30 days.
    I then had a call-back from my "case manager" 30 minutes later, comfiming all details etc.
    So, FINGERS CROSSED
    Will let you know the outcome.
  3. Re: Injector Failures - Possible recall
    Dec 2010
    Chester Cheshire
    I'll tell you the outcome....You will get all your money back, no quibble.........I got my cheque for £1500 for 2 injectors I paid for last year from VW. 100% satisfied !
  4. Re: Injector Failures - Possible recall
    I got to say VW have been very good about this. The customer service has, so far, been second to none.
  5. Re: Injector Failures - Possible recall
    Nov 2011
    London
    My 2006 Golf GT 2.0 170bhp had an injector failure on saturday. VW are replacing all four for free. However back in august 2010 I had number 2 injector replaced by a VW specialist at a cost of £900 quid. Do I get my new injectors for free AND a refund for the previous work? VOSA dont seem to be answering their phone.
  6. Re: Injector Failures - Possible recall
    Nov 2011
    moray scotland
    In my not very expert opinion i would say you can claim for the injector it was still a failure as long as you have the paperwork to back it up. VW are replacing your injectors out of goodwill you are still £900 out of pocket. Phone them and register your claim youve nothing to lose.
  7. Re: Injector Failures - Possible recall
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by jhjl View Post
    .......VOSA dont seem to be answering their phone.
    They're probably on strike.....
    1996 Laguna 2.2D
    1977 MGB roadster
  8. Re: Injector Failures - Possible recall
    135 Post(s)
    2026 Post(s)
    This is a brief précis of the VW UK Service Action 23H9 regarding Piezo pump injectors.
    The repair instructions are contained in Technical Product Information (TPI) transaction number 2027647
    This applies to 2.0TDI PD Golf, Passat, and Touran with PD Piezo Injectors
    There are approximately 78,800 (model years 2006 – 2010) affected vehicles in the UK.
    Owners will receive communications from Volkswagen UK on a phased basis.
    The following vehicles with the engine codes listed are affected.
    Passat 3C 2006-2008 with the BKP, BMA, BWV, BVE, BMR, and BUZ engines
    Golf 5 2006-2009 with the BMN engine
    Touran 2006-2010 with the BMN engine
    Technical background
    On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil. This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open campaigns/measures are performed during the workshop visit.
    Parts to be fitted as part of this campaign.
    1x Campaign 23H9 sticker 000 010 006
    1x Wiring loom adapter 03G 971 033 M
    4x Adjustment screw WHT 000 530
    5x M8x58 socket head bolt N 105 811 01
    8x M6x88 socket head bolt 03G 103 385 A
    4x Pump injectors
    If the vehicle is listed in the system as not completed, check whether a campaign sticker with the entry "23H9 date/stamp" is attached in the spare wheel well area (next to data sticker):If the campaign sticker is attached, the campaign has already been performed. Make the entry “23H9 date/stamp” in the service schedule under “Space for workshop entries”.
    If the campaign sticker with entry "23H9" is not fitted, carry out the work according to the repair instructions.
    Identifying the potentially faulty injectors.
    Remove cam cover and check the part number –see arrow- on the pump injector element. All pump injector elements with the part number 03G 130 073 D or 03G 130 073 M must be replaced. All other pump injector elements are correct and must not be replaced.
    5 0 0
  9. Re: Injector Failures - Possible recall
    Feb 2010
    London, UK
    Are they supposed to fit brand new injectors? As all of mine have turned out to be refurb/exchange parts. He also told me he thought they were Bosch units.
    After having my injectors fail again, I took it to VW who charged me £120 to shrug their shoulders and say 'dunno'. They then said it would cost £600 to run a parallel loom to see if the problem was faulty wiring, so I told them to go fish.
    Having taken it to a local mechanic who worked for VW as a reporting tech, he charged me £100 to run a parallel loom, and fit and retry each injector on a different cylinder, coming up with 3 of the 4 injectors had failed.
    He also told me at that point were all exchange/refurb injectors as denoted by the parts being stamped with SX at the end.
  10. Re: Injector Failures - Possible recall
    135 Post(s)
    2026 Post(s)
    The injectors are always exchange units and as far as I know they are Siemmens. I have had two failures of new injectors.
  1. Attention 2.0 tdi Injector failures - information
    By mm707 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-04-2011, 06:25 PM
  2. Audi 170 PS Injector Failures (A3s and A4s) - VOSA action
    By jfarhead in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-04-2011, 10:42 PM
  3. Question Injector failures - some info required please
    By mm707 in forum Chat - Anything with wheels
    Last Post: 26-03-2011, 08:38 PM
  4. Injector loom recall?
    By skartsocket in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-09-2009, 01:41 PM
  5. Seat Belt Recall Problems / Recall?
    By ChillOut in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 02:48 PM
