Thread: power steering rack part number?
Page 1 of 10 123 ... LastLast
Results 1 to 10 of 96
  1. power steering rack part number?
    Oct 2009
    Redcar
    hey, i have a 2004 audi a3 2.0 tdi sport.. needs a new power steering rack
    whats the part number i need please??
    thanks,
    i have found one with this part number.. 1K2423051BB
    would it fit?
    thanks!
    http://auditips.weebly.com/ - its my website and blog! worth a look
  2. Re: power steering rack part number?
    1840 Post(s)
    That will possibly fit but you need to establish the part number of the rack fitted to your car first as some conversion parts may be required.
  3. Re: power steering rack part number?
    Oct 2009
    Redcar
    any ideas how i would go about doing that? without taking off the rack
    thanks for the help!
  4. Re: power steering rack part number?
    1840 Post(s)
    PM me your registration number.
  5. Re: power steering rack part number?
    1840 Post(s)
    From your chassis number it looks like your car will have a generation 2 steering rack as this was introduced at chassis WAUZZZ8PX4A090001, its close though because there is the annoying asterisk after that chassis number which means the change point is vague but I think you are far enough away at just under 7000 cars later. With your chassis number I can see the rack you would need is VAG part number 1K2 423 055 J and according to ETKA you will need a wiring set, part number 1K2 971 111 AJ if you use that rack. The rack you have found, part number 1K2 423 051 BB changed to 1K2 423 055 F and then 1K2 423 055 J so I think you should be able to fit the rack you have found and you will not need the wiring adapter set.
  6. Re: power steering rack part number?
    Oct 2009
    Redcar
    wow! thankyou very much for your help. i'm over the moon that i can buy that rack, knowing that it 'should' go on my car. and its only costing me £50 off ebay! so thats great.
    i appreciate your help lots! thanks very much!
  7. Re: power steering rack part number?
    Oct 2009
    Redcar
    replaced the rack thanks a lot!
    it works, but not very well.. do you know if it needs configuring with vagcom?
    thanks
  8. Re: power steering rack part number?
    1840 Post(s)
    Yes it most certainly does and sometimes even a registered copy of the latest VCDS will not do it, I often have to use the dealer system VAS PC.
  9. Re: power steering rack part number?
    Oct 2011
    London, United Kingdom, United Kingdom
    hello, i wonder if you can help, i have a similar problem and i need to replace the steering rack. my car is an A3 2.0 FSI (2004 model) vin is WAUZZZ 8P14A029412
    i really appreciate your help
    regards
    Evan
  10. Re: power steering rack part number?
    1840 Post(s)
    A very early 8P A3 and almost certainly this car will have the first generation rack fitted so if you wish to change to a Gen 2 rack there are some conversion steps required.
    1 1 0
  1. Power steering rack
    By csmccoll68 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-07-2011, 11:47 PM
  2. Audi A4 B5 Power Steering Rack
    By gorillamonsoon in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-08-2010, 05:53 PM
  3. Power steering rack replacement
    By erichos in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-02-2009, 09:07 PM
  4. 2003 VW Polo Power Steering Rack Q
    By SteJay in forum Polo - Derby - Lupo - Fox
    Last Post: 07-02-2008, 07:13 PM
  5. Steering Rack Repalcement Part
    By inertia in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-12-2007, 12:01 AM
