Thread: power steering rack part number?
Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 96
  1. Re: power steering rack part number?
    #81
    1836 Post(s)
    Eddie, your car has a Gen2 rack, part number 1K2 423 055 C so you wouldn’t fit a GEN1, part numbers 1K2 423 051 CG, CH, CJ, CK or fit one earlier than yours so look for 1K2 423 055 C, D, E, F, G, H, J, K or L but J, K and L are GEN3.
  2. Re: power steering rack part number?
    #82
    Apr 2017
    Kuala Lumpur, Malaysia
    Thanks for the quick reply crasher, coming from the pro himself haha. Vr much appreciated. Cheers.
  3. Re: power steering rack part number?
    #83
    Apr 2017
    Hi again,
    I decided to give it a scan with my VCDS regarding the problem. 2 faults came out. No suprise there.
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 J
    Component: EPS_ZFLS Kl.5 D04 1606
    Shop #: WSC 00000 000 00000
    VCID: 3365447B527706A690-8066
    2 Faults Found:
    00003 - Control Module
    014 - Defective
    00778 - Steering Angle Sensor (G85)
    000 - - - Intermittent
    I cleared the code and something funny happened. The red steering warning light disappeared like it's supposed to, and the power steering works like a charm again! I have yet to give it a drive but the steering wheel turns fine from end to end in the parking lot. Does it mean it still needs to be replaced or it's just working intermittently before it decides to go belly up again?
  4. Re: power steering rack part number?
    #84
    1836 Post(s)
    The fault will probaly come back.
  5. Re: power steering rack part number?
    #85
    Apr 2017
    Is it safe to say that the steering box is the culprit?
  6. Re: power steering rack part number?
    #86
    1836 Post(s)
    The controller and angle sender are inside the rack.
  7. Re: power steering rack part number?
    #87
    Apr 2017
    Crasher, woukd you be able to tell me the part number of second hand racks that I would be able to fit to my car?
    REG-NV57 RRO
    VIN-WVWZZZ1KZ8W192710
  8. Re: power steering rack part number?
    #88
    1836 Post(s)
    Your car has a late GEN2 rack and so is probably 1K2 423 055 E or possibly F but the next step is GEN3 and that means using the conversion harness. The best way to know what is in there is with a code read but doing the job with an exchange Bosch rack means not having to search high and low and compromise the job.
  9. Re: power steering rack part number?
    #89
    Apr 2017
    If my car was fitted with a 1K2423055e and I fitted it with the F varient, would this affect it in anyway?
  10. Re: power steering rack part number?
    #90
    1836 Post(s)
    Not as far as I can work out from the VIN breaks and part number supersession dates as the last GEN2 rack was the F BUT as I said, I have never done this and never would.
  1. Power steering rack
    By csmccoll68 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-07-2011, 11:47 PM
  2. Audi A4 B5 Power Steering Rack
    By gorillamonsoon in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-08-2010, 05:53 PM
  3. Power steering rack replacement
    By erichos in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-02-2009, 09:07 PM
  4. 2003 VW Polo Power Steering Rack Q
    By SteJay in forum Polo - Derby - Lupo - Fox
    Last Post: 07-02-2008, 07:13 PM
  5. Steering Rack Repalcement Part
    By inertia in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-12-2007, 12:01 AM
