Thread: Intake Manifold Runner adaption
  1. Intake Manifold Runner adaption
    Feb 2011
    Winchester
    I've been getting the faults listed later on my 2006 A6 2.7 TDi Avant and diagnosed the bank 2 intake manifold (swirl flap) motor as being faulty (that's the one on the right hand side when you stand in front of the car). You could see that it was not doing the same thing as the other motor. There are some good forum entries which have helped a lot in diagnosis.
    Found a new motor on eBay, without the flaps. £95, brand new, bargain.
    Part number 059129086
    I have read on the Ross-Tech wiki that I need to adapt the new motor when I replace it. Motor hasn't arrived yet so tonight I thought I'd just try the adaption instructions using vagcom from the Ross-Tech website which says that it's group 142, in the basic setting of the engine controller. That group is not found, which made me wonder if there is one group number for bank 1 and another for bank 2?
    Anyone done this before, it seems like a fairly common fault.
    <info>
    012597 - Intake Manifold Runner Control: Lower Stop not Reached
    P3135 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 15
    Mileage: 217228 km
    Time Indication: 0
    Date: 2011.06.10
    Time: 18:03:08
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Voltage: 12.24 V
    Duty Cycle: 88.8 %
    Duty Cycle: 20.5 %
    Duty Cycle: 20.5 %
    004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
    P1018 - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 105
    Mileage: 217228 km
    Time Indication: 0
    Date: 2011.06.10
    Time: 18:22:03
    Freeze Frame:
    RPM: 756 /min
    Torque: 39.0 Nm
    Speed: 0.0 km/h
    Voltage: 13.60 V
    Duty Cycle: 80.9 %
    Duty Cycle: 88.8 %
    Duty Cycle: 80.9 %
    Adaption procedure from Ross-Tech
    Prerequisites:
    * Ignition ON
    * Engine OFF
    * System voltage at least 11.0 V.
    [Select]
    [01 - Engine]
    [Basic Settings - 04]
    Group 142
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    Wait until Field 4 shows "ADP. O.K.".
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    * Switch Ignition OFF for at least 60 seconds.
  2. Re: Intake Manifold Runner adaption
    Aug 2011
    Phoenix, AZ, USA
    I had an intake runner problem at one time, I found it was a cracked vacuum line. Might be something to look into.
    Sam
  3. Re: Intake Manifold Runner adaption
    1840 Post(s)
    059129086 changed to 059 129 711 T then 059 129 71 AG then 059 129 711 AF then 059 129 71 AL then 059 129 711 BP then 059 129 711 BQ and finally (so far this week) to complete unit 059 129 711 CG
    It is an extremely common fault for the V157 and V275 motors to come up on a code read on these engines and normally you need the complete manifold to go with it and this is why you find the motors for sale on fleaBay as people have bought them (059 129 086) and then found they will have to by the complete manifold that comes with the motor, 059 129 711 CG (left) and 712 BL (right) so they end up with two motors and stick on up for sale to cut their loses.
    Check fuse 12 is ok in the main fuse box in the plenum chamber.
    Without the VAG tester VAS 6395/1 it is not possible to carry out the motor test so most people just fit them and hope for the best. Sometimes Group 142 works.
  4. Re: Intake Manifold Runner adaption
    Feb 2011
    Winchester
    Thanks crasher, thats very helpful. More part numbers I can look for.
    Why do you have to replace the whole unit? What is it about the flaps that breaks or means that just replacing the motor does not clear the fault.
    BTW
    When the motor turned up I plugged it in and it exhibited eactly the same fault as the knackered one. It would do a limit to limit test, when you turned the ignition on, but would not actuate when you were revving above 1250 rpm. I can swap the LH bank swirl flap motor to the RH bank and the fault moves so I know that it's the motor.
    FWIW The ebay seller never communicated with me when I asked for a refund and after a week eBay gave me my money back. They sent me a postage voucher and I sent it back to him.
    Thanks, this is a great forum. Big
  5. Re: Intake Manifold Runner adaption
    1840 Post(s)
    The linkages wear and they do not come with the motor, they only come as the complete assembly. If it was a 1970’s British car you would be able to buy every single part you need individually, that’s progress for you!
  6. Re: Intake Manifold Runner adaption
    Quote Originally Posted by big View Post
    BTW
    Did you sort this with a complete unit in the end?
  7. Re: Intake Manifold Runner adaption
    Feb 2011
    Winchester
    No, my current plan - when I get time -is to add 3mm of washers to raise the motor from the engine block. Apparently this takes out the play in the linkage. There was a discussion on the audi sport forum and I thought I'd give that a go. Backup plan is to manufacture new linkages using ball and socket joints available from RS Components.
    Given that I can't complain about the MPG or the smooth running of the engine and the MOT tests have not focussed on dashboard management information lights then the incentive went away.
    Cheers, Rob
  1. Please Help 004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-05-2017, 06:45 PM
  2. Please Help Intake manifold runner control fault
    By A3Quattro in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-09-2014, 04:51 PM
  3. 004120 - Intake Manifold Runner - need TPI 2016504
    By TheMatador in forum 3.0TDi - Engine
    Last Post: 16-07-2014, 11:43 PM
  4. audi 3.0 diesel intake manifold runner motor problem
    By daniel_3855 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-10-2013, 01:07 AM
  5. Intake manifold runner control basic setting
    By grabread in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 02:02 PM
