Thread: Audi A3 front washers and rear wiper not working
  1. Audi A3 front washers and rear wiper not working
    May 2010
    Devon England
    as title the front washers and rear wiper is not working on the A3, here is the scan ive got, any ideas?????
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 76
    VIN: WAUZZZ8P17A125996 Mileage: 112050km/69624miles
    01-Engine -- Status: Malfunction 1010
    15-Airbags -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0021121
    Shop #: WSC 06314 000 00000
    VCID: 73CB11076B25
    1 Fault Found:
    01314 - Engine Control Module
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
    Component: KlimavollautomatH19 0360
    Revision: 075040 Serial number: 8P0820043AC
    VCID: 6DFF077F0D01
    No fault code found.
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000006431949
    Coding: E4885F01B014100000160000160000000008FA175C0100
    Shop #: WSC 06314 000 08192
    VCID: 40A18ECB6A13
    Part No: 8P2 955 119 E
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Part No: 4E0 910 557 A
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150573
    Shop #: WSC 06314
    3 Faults Found:
    02398 - Control Circuit for Rear Windshield Washer Pump
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 55
    Mileage: 112056 km
    Time Indication: 0
    Date: 2011.06.27
    Time: 13:32:00
    Freeze Frame:
    ON
    Voltage: 12.10 V
    OFF
    ON
    OFF
    OFF
    OFF
    02401 - Terminal 75x
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 55
    Mileage: 112056 km
    Time Indication: 0
    Date: 2011.06.27
    Time: 13:32:00
    Freeze Frame:
    ON
    Voltage: 12.10 V
    OFF
    ON
    OFF
    OFF
    OFF
    00897 - Windshield Washer Pump (V5)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 55
    Mileage: 112056 km
    Time Indication: 0
    Date: 2011.06.27
    Time: 13:32:00
    Freeze Frame:
    ON
    Voltage: 12.10 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H13 4260
    Revision: 91H13426 Serial number: 003620G321A0
    Coding: 0071612
    VCID: 42A584C3641F
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0000022
    VCID: 41A78BCF6119
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 951 D HW: 8P0 920 951 D
    Component: KOMBIINSTR. VDO H20 0570
    Revision: D0H20004 Serial number: 124NF004002896
    Coding: 0004413
    Shop #: WSC 00019 210 90927
    VCID: 364DE81338D7
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H12 0170
    Revision: H12 Serial number: 3300106B1081CF
    Coding: 3D3F074207002103
    VCID: 2F43DD77C78D
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 95
    Mileage: 112056 km
    Time Indication: 0
    Date: 2011.06.27
    Time: 13:24:20
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20004 Serial number: AUX7Z0FNFNN0I0
    Shop #: WSC 00000 000 00000
    VCID: 364DE81338D7
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000760
    VCID: 40A18ECB6A13
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.078 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 354FEF1F25D1
    1 Fault Found:
    Freeze Frame:
    Mileage: 112040 km
    Temperature: 27.0°C
    Voltage: 12.00 V
    Voltage: 11.80 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 F
    Component: KSG H08 0070
    Coding: 9980202002186D098505489FC637
    VCID: 3FA38D3717ED
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH04 0180
    Revision: 00003 Serial number: 30674696920808
    VCID: F1C79B0F9139
    1 Fault Found:
    00421 - Left Rear DSP Midrange Speaker (R105)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00111011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 82
    Mileage: 111736 km
    Time Indication: 0
    Date: 2011.06.20
    Time: 14:22:04
    Freeze Frame:
    Temperature: 21.0°C
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000760
    VCID: 41A78BCF6119
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 195 G HW: 8P0 035 195 G
    Component: R Symphony2+ H14 0220
    Revision: 00H14000 Serial number: AUZ1Z4F9005102
    Coding: 0010211
    VCID: 364DE81338D7
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 D
    Component: Tuer-SG 020 0070
    Coding: 0000216
    VCID: 40A18ECB6A13
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 D
    Coding: 0000216
    VCID: 41A78BCF6119
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
    Component: Parkhilfe 4-Kan H09 0060
    Revision: 00H09000 Serial number: 00067824830632
    Coding: 0000013
    Shop #: WSC 131071 1023 2097151
    VCID: 3C59FA3B06FB
  2. Re: Audi A3 front washers and rear wiper not working
    Jan 2010
    Wakefield, West Yorkshire
    See if this helps to start with.
    Looks to me like fault codes are stored and no comms for some reason.
    Has it been re-mapped ?
    http://wiki.ross-tech.com/wiki/index.php/01314
  3. Re: Audi A3 front washers and rear wiper not working
    Jul 2009
    liskeard cornwall
    sounds like the wiper stalk might have failed
    0 0 1
  4. Re: Audi A3 front washers and rear wiper not working
    Apr 2012
    ontario canada
    I had the same thing happen it ended up being terminal 75x relay under the fuse panel on the drivers side
  5. Re: Audi A3 front washers and rear wiper not working
    Mar 2012
    Denmark
    Did you find the fault ? i have a Touran from 2013 that have the same faukt an i think it is the can gateway that have a fault
  6. Re: Audi A3 front washers and rear wiper not working
    1837 Post(s)
    8P A3 rear wiper motors are useless, witness the number of them you see stuck in various positions on cars driving around.
  1. Rear Wiper not working
    By Silver_Giraffe in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-11-2012, 11:08 AM
  2. Question Rear wiper not working
    By whatsup7 in forum Golf MK5 - 2004 - 2009
    Last Post: 03-05-2010, 02:03 PM
  3. Please Help Rear washers not working - NOT the usual problem...
    By MrShades in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2010, 01:48 PM
  4. One front wiper not working,
    By biggraham in forum Altea
    Last Post: 27-03-2009, 08:08 PM
  5. rear wiper not working
    By colly27 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-01-2008, 10:53 AM
