Thread: Vento 1995 1.9 diesel overheating
  1. Vento 1995 1.9 diesel overheating
    Apr 2011
    york uk
    Please can someone tell me where the thermostat is located on this engine as I need to check it out.
    I will also flush the system out as it has never been done for at least 7 yrs
    Its a strange one, it only starts to overheats after about 25 miles and then if I go steady on the revs I can keep it from getting to hot! The rad and bottom hose feels a lot colder at the bottom when its hot at the top hose! I have never let it boil and it does not use a lot of water if any. I know its not an electrical fault and the fans work when its gets hot near the switch in the rad.
    Any ideas or advice is as always very much appreciated.
    Thanks.
  2. Re: Vento 1995 1.9 diesel overheating
    Apr 2011
    york uk
    I had a good look at it. I flushed the cooling system out as much as I could, not a lot of crud came out. I have checked the circulation and found a small crack in the plastic 'tree' junction flange that bolts to the head, the one with the top hose and a couple of smaller hoses and temp sender on it. I will get another but I have used silicon as a temporary repair for now. This crack may have caused air to get in and upset things! It was not a large crack and hardly any coolant leaked out of it. We will see how it goes and if ok I will be looking for a cheap housing/flange. I have bled the system and I have noticed that it is important for the cooling system to have the cap tight to keep it pressurised for it to work well. The rad fans and heater work ok. Hope this helps anyone having similar problems.
  3. Re: Vento 1995 1.9 diesel overheating
    Apr 2011
    york uk
    Running hot seems to be cured, after 700 mile its keeping its cool, the very small leak is weeping but not getting worse, yet! It only uses an egg cup of coolant a day so I'm not to bothered but trying to find a cheap replacement 'plastic' temp sensor housing is proving a hard one.
  4. Re: Vento 1995 1.9 diesel overheating
    Sep 2009
    London/Bucks England
    It might be getting airlocked aswell from the leak, so when it cools it sucks air back in via that crack. when the system is under pressure the coolant will evaporate out via the crack, its worth replacing it anyway imo.
    151 PS @ 3800 rpm 1.6 8V MPi - 31.5mpg urban <-- Happy days
    123k On the clock and counting. (25k on the block)
    I need all your V-Powers.
  1. Please Help 80 2.0E (1995) Major overheating problem
    By Cadiddy in forum 80 - 90
    Last Post: 09-03-2011, 11:00 PM
  2. Please Help Vento Diesel Suddenly Dropping power
    By teddyracingcouk in forum Vento - 1994 - 1998
    Last Post: 23-08-2008, 05:45 PM
  3. Caravelle 2.4 Auto Diesel 1995
    By NOK in forum The Commercial Range
    Last Post: 01-03-2008, 10:46 AM
  4. Fault with glow plugs on 1995 diesel vento
    By ManiacMunz in forum Vento - 1994 - 1998
    Last Post: 22-02-2008, 06:22 PM
  5. VENTO 1995 WHEEL BEARINGS
    By FINDAD in forum Vento - 1994 - 1998
    Last Post: 07-12-2006, 09:16 AM
