Thread: Allroad suspension air compressor part no
Results 1 to 10 of 11
  1. Allroad suspension air compressor part no
    Sep 2008
    Highlands
    12 Post(s)
    Hi all
    does anyone know what the part number for the suspension air compressor is on a 2003 Allroad. I ordered one from my parts supplier and they sent an air con compressor out. They cant get the suspension compressor without a part no. Also any names of manufacturers of the after market compressors would be really helpful.
    Vin
  2. Re: Allroad suspension air compressor part no
    Ayrshire, Scotland
    14 Post(s)
    The part number for the suspension compressor is 4Z7 616 007A. the original was a continental, I don't think these are available any more, then Wabco and now Arnot offer a replacement also one claiming to be OEM found here on http://cgi.ebay.co.uk/compressor-air...item5d29f5f6a8 396. google or ebay brings them up.
    I don't think local motor factors will supply them.
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Allroad suspension air compressor part no
    Ayrshire, Scotland
    14 Post(s)
    Why are you changing it?
  4. Re: Allroad suspension air compressor part no
    Sep 2008
    Highlands
    12 Post(s)
    cheers Andy
    I was considering putting that in the buying allroad thread because I thought you might know!!! I havent had a chance to put the VCDS on it yet but will report back as soon as I do.
    Thanks again for all your help. its much appreciated.
    Vin
  5. Re: Allroad suspension air compressor part no
    Sep 2008
    Highlands
    12 Post(s)
    I wont change it until I am satisfied that I have no leaks and that everything is working as it should be . The fact that it is noisy is helpful at the moment as I can monitor how often it cuts in . It is getting very agricultural though I know the bose stereo is good but even it is struggling to drown out the compressor so I assume it is only a matter of time .
    Vin
  6. Re: Allroad suspension air compressor part no
    Ayrshire, Scotland
    14 Post(s)
    don't rush into buying one, I think you previousy said it was running too much, this could be another fault, get the fault codes, however if it is noisy it could well be needing replaced but personally I would leave it until it gives in, Unless it is really, really, really noisy!!
    when buying from ebay, the link i sent is a direct replacement, straight swap, beware others do not have the thermal cut of switch and need plugs and cables cut and swapped over, if you need a new one, choose wisely.
    Andy
  7. Re: Allroad suspension air compressor part no
    Ayrshire, Scotland
    14 Post(s)
    Posted at the same time!!
  8. Re: Allroad suspension air compressor part no
    Sep 2008
    Highlands
    12 Post(s)
    Hi Andy
    I checked with Dingbro on availability they could get a wabco one for 596 so needless to say I just ordered the ebay one . I got it for best offer 370.
    I still have not had a chance to check fault codes yet . hopefully tomorrow eve weather permitting.
    Vin
    ps Has wind around doors at speed ever been an issue you are aware off?
  9. Re: Allroad suspension air compressor part no
    Ayrshire, Scotland
    14 Post(s)
    Ok there goes the don't rush into buying one!!
    Quote Originally Posted by vinpetrol View Post
    Yes, this is probably, (not definately) due to the window clip being broken which stops the window being pulled right up into the seal,
    to check try to see if the window will go higher into the rubber, with the door open and a hand on each side of the glass, can you lift the glass further to stop the whistle?.
    My drivers one did this, it was more obvious on the pass side as the window would jam when raising.
    The part is very cheap to buy from audi, part number 4B0 837 463B (2.20 + VAT), see link to thread: http://www.vwaudiforum.co.uk/forum/s...c-window-on-A6
    Andy
  10. Re: Allroad suspension air compressor part no
    Apr 2009
    Epsom Downs
    Well, firstly, I'm suurprised you can hear any wind noise above the diesel engine (not to mention the compressor!), unless we're talking three figures?
    It could just be adjustment... See if you can trap a business card all around the door seal. If it falls out anywhere, and it looks proud on the outside, there's your problem.
    The striker plate can be adjusted to pull it in a bit, but if you've run out of adjustment (and the seal is in good condition) it might be time for a new name in the log book..
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  1. Allroad suspension compressor
    By 27allroadpetrol in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2011, 02:09 PM
  2. allroad suspension compressor and vag-com?
    By Grizgut in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-10-2010, 07:41 AM
  3. Allroad air compressor testing?
    By robbyallroad in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-09-2010, 09:46 AM
  4. Allroad Suspension Compressor
    By Boothyboy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-08-2010, 08:50 AM
  5. air con compressor part no????
    By b9g in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-05-2009, 10:16 AM
