Thread: "Tch Tch" noise when moving (wheels right,left or straight)
Results 1 to 10 of 15
  1. "Tch Tch" noise when moving (wheels right,left or straight)
    Jul 2007
    Chester
    I have a strange noise coming from the front...It is like " tch tch" ...I can feel it through steering wheel... It takes only a second and only once and it only happen when I start engine and move forward (wheels are straight or left or right),never on reverse, it never happened if I stopped the car (engine on), clutch down or neutral and moved forward again.
    So it only happen when engine is off and then again on... Any idea?
    Audi TT 1.8T Quattro 225 - Sold , AUDI A4 1.9 TDI 130 AWX - now
  2. Re: "Tch Tch" noise when moving (wheels right,left or straight)
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    ABS system powering up
  3. Re: "Tch Tch" noise when moving (wheels right,left or straight)
    Jul 2007
    Chester
    But why I didn't hear it before ? If it is ABS system why I feel it as kick in the steering wheel? Is it normal ?
  4. Re: "Tch Tch" noise when moving (wheels right,left or straight)
    Apr 2009
    Check your power steering pulley and belt
    Regards
    Jim
  5. Re: "Tch Tch" noise when moving (wheels right,left or straight)
    Jul 2007
    Chester
    Quote Originally Posted by yaman View Post
    Regards
    Jim
    Belt was replaced about 5,000 miles ago. Pulley runs smoothly. It is really hard to diagnose as it only happen when moving. Sound is really similar as seized alternator clutch pulley, but I am assuming I would hear it also when stacionary rurning wheels to full lock....
  6. Re: "Tch Tch" noise when moving (wheels right,left or straight)
    Apr 2009
    Quote Originally Posted by sabikeuk View Post
    Does it still happen if the air-con is off?
    Regards
    Jim
  7. Re: "Tch Tch" noise when moving (wheels right,left or straight)
    Jul 2007
    Chester
    I have mostly air-con off (ECON) so yes ...
  8. Re: "Tch Tch" noise when moving (wheels right,left or straight)
    Apr 2009
    Do you think it could be coming from the DMF area, and not the front?
    Regards
    Jim
  9. Re: "Tch Tch" noise when moving (wheels right,left or straight)
    Jul 2007
    Chester
    It's hard to says...I think it is rather from suspension then clutch.
    I changed clutch 3 months ago (only clutch kit not DMF as there wasn't much movement-only 10mm).
  10. Re: "Tch Tch" noise when moving (wheels right,left or straight)
    Apr 2009
    Its because you have to restart the engine (to make it happen again) that has me thinking along the lines
    of centrifugal force doing something to the springs of the DMF (after initial clutching) which causes it to
    not do it again, until the flywheel stops turning.
    Its a strange one alright.
    Regards
    Jim
  1. Vredestein Wintracs - do they fit "standard" S Line 18" wheels?
    By wj209980 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-03-2011, 10:11 PM
  2. A "Community" a "Club" or a "Technical Forum"?
    By stuart in forum Chat - Completely Off Topic
    Last Post: 07-03-2009, 02:11 AM
  3. S6 "Left bank running lean"
    By toff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-08-2007, 01:42 AM
