Thread: wheres my limit?
  1. wheres my limit?
    May 2011
    Chesterfield, United Kingdom
    hi iv got a 96 vento and i have found wheels i love but need to no if i could fit a 15" 7J with 45mm offset on a 15mm spacer/pcd adaptor to my car?
    or can anyone tell me what i can fit mainly looking for offset/rim thickness planin on 15/16" tires would be somthing like 205/50/15 not shure with the 16's
    p.s im prity shure the vento's the same set up as the mk3 golf
    thanks for any help
  2. Re: wheres my limit?
    1834 Post(s)
    The official line is that a 6x15 should be an ET 45 and a 6.5x15 should be an ET43 so I would say ideally a 7x15 would need to be ET40 so you would need a 5-mm spacer. The 4 stud PCD of a Golf a Vento is 4x100 M12.
  3. Re: wheres my limit?
    May 2011
    smallest i can get is 15mm pcd adaptor and there costum 1's at that aswell from ebay i gess ET is off-set and gess all this means is that no i cant fit classic audi quattro wheels on my vento
  4. Re: wheres my limit?
    1834 Post(s)
    I do not know of a PCD adapter thinner than 15-mm. As they are made of ally they have to be a good 50% thicker than a steel wheel hub. An ET45 with a 15-mm spacer makes ET30 and with a 195 tyre on a 7” rim this may just work with a little clearancing on the arches but it could make the steering feel odd.
  1. What Oil and wheres cheapest?
    By pbriggs in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-08-2010, 09:50 PM
  2. Question wheres my post gone
    By hodgy_7 in forum Early Passat Forum - Pre 97
    Last Post: 09-05-2010, 06:51 PM
  3. Wheres my Fuse box?
    By jon_viola in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 08-01-2010, 01:16 PM
  4. Wheres all the info
    By spiker in forum Audi A3 - Archive Topics
    Last Post: 06-02-2007, 05:45 PM
  5. Wheres the 'Magic' plug???
    By Marc97 in forum Chat - Completely Off Topic
    Last Post: 18-11-2006, 12:50 AM
