Thread: Audi A6 2.5 TDI Quattro Remap
  1. Audi A6 2.5 TDI Quattro Remap
    Sep 2008
    I'm looking to remap my 54 plate 2.5tdi quattro A6. What gains should I expect in bhp, nm, mpg. How much should I be looking to pay. Also who would be good to contact, based between Portsmouth and Guildford.
  2. Re: Audi A6 2.5 TDI Quattro Remap
    Jun 2011
    uk
    You should see gains of +35bhp & somewhere in the region of 45nm increase in torque.
    as for the mpg, driving 'normally' you may see some improvement in mpg.
    i would recommend Elite remaps, they have a national dealer network and are Vag specialists
  3. Re: Audi A6 2.5 TDI Quattro Remap
    Quote Originally Posted by dervmeister View Post
    would you indeed?
    On the basis of what, may I ask, are you making this recommendation?
    My moddy senses are twitching, so consider your reply carefully.
  4. Re: Audi A6 2.5 TDI Quattro Remap
    london/ UK
    Quote Originally Posted by hmradcliffe View Post
    Expect about 200 to 210 Bhp and 440-480 Nm depending on engine code and turbocharger fitted. The a6 has plastic ended intercooler so high boost wont hold too well. Also depending on engine code you could have a 3 plunger pump(most are 2 plungers only) and the larger Gt2052 turbo wich has a slightly bigger compressor wheel. I found the early a6 respond much better to tuning as they have less emission restraints. I would ditch the pre-cat and the main cats if it's performance you after... There's plenty turners out there but few understand the quircks of the v6 engine and vp44 pump...
  5. Re: Audi A6 2.5 TDI Quattro Remap
    Jun 2011
    uk
    Quote Originally Posted by Eshrules View Post
    would you indeed?
    Had a couple of cars 'mapped' by them in the past with no problems and the dyno say's so , simple as ;-)
  1. What is the difference between the audi a4 tdi quattro and the audi a4 tdi tdv quattro
    By john-mandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-06-2010, 05:54 PM
  2. new 3.0 TDI Quattro remap / chip advice
    By V5 Man in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-03-2010, 12:59 PM
  3. audi a6 quattro 1.8t remap help
    By kickthis in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-09-2009, 09:16 PM
  4. audi a6 quattro 1.8t remap help
    By kickthis in forum New Member Introductions
    Last Post: 14-09-2009, 11:28 PM
  5. Audi V6 2.5 Tdi Remap
    By wadi110 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-07-2008, 08:23 PM
