Thread: Intake manifold runner control fault
Results 1 to 10 of 10
  1. Intake manifold runner control fault
    Oct 2010
    Stone, Bedfordshire
    I have a 2007 2.0 TDI Quattro A3. Driving the other day and the blasted glow plug light started flashing, AGAIN....
    The car stayed in normal driving mode and when I stopped for fuel the fault didn't come back straigh away - it took about ten minutes. Later that day I drove about 100 miles with no flashing glow plug.....
    Upon insoection with VCDS I have got the following fault:
    VCDS Version: Release 10.6.4
    Data version: 20110418
    Sunday,29,May,2011,18:18:01:41539
    Chassis Type: 1K0
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
    Component: R4 2.0l PPD1.2 4350
    Revision: --H42--- Serial number: AUX7Z0G1FN60H4
    Coding: 0000172
    Shop #: WSC 06441 785 00200
    VCID: 74E25C276E2B
    1 Fault Found:
    012600 - Intake Manifold Runner Control: Regulation Deviation
    P3138 - 006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 33
    Mileage: 144405 km
    Time Indication: 0
    Date: 2011.05.27
    Time: 14:32:34
    Freeze Frame:
    RPM: 2688 /min
    Torque: 48.0 Nm
    Speed: 28.0 km/h
    Mass Air / Rev.: 675.8 mg/str
    Mass Air / Rev.: 637.7 mg/str
    Lambda: -22.7 %
    Text: Kein Messwert verfuegbar
    Readiness: N/A
    Can any one shed some light into the cause of this problem?
    Much appreciated,
    Alan
  2. Re: Intake manifold runner control fault
    135 Post(s)
    2027 Post(s)
    So you have a BMN engine. This is probably a faulty V157 inlet manifold motor.
    Oct 2010
    Stone, Bedfordshire
    Hi, is there anything wrong with a BMN engine?
    I've had two injectors replaced in the last couple of months!! Thankfully Audi paid 100% of the bill each time......
    If the fault happens again I might change the motor. Are they easy to change. No doubt they will cost a small fortune!
    Cheers Al.
    I use VCDS and will help nice folk.....
  4. Re: Intake manifold runner control fault
    135 Post(s)
    2027 Post(s)
    There is nothing particularly wrong with a BMN, it is just that you had not told us so I stated it for the benefit of others. The motor is easy to change but expensive.
  5. Re: Intake manifold runner control fault
    Jan 2012
    Coding Something
    Hi Crasher, does it need to be dismantled internally for the flaps to be replaced or just the motor swapped externally mate, TIA.
  6. Re: Intake manifold runner control fault
    135 Post(s)
    2027 Post(s)
    It is normally just a matter of changing the motor BUT I have also seen damaged linkages.
    1 1 0
  7. Re: Intake manifold runner control fault
    Jan 2012
    Coding Something
    Thanks for the speedy reply mate, missus car has the errors, adapted, but they return & seems down on power & says economy also down, so I will grab a motor & swap out, seems fairly straight forward, just pita to get to bolts, soon find out when this bloody rain stops lol.
    If its the linkages then its a whole new manifold, she wont like that as the cam lobe wore a hole through, rounded cam of & fuel pump nipple worn to an angle, ouch, lucky I could do most except the cam, but 2 year warranty with audi on that work.
  8. Re: Intake manifold runner control fault
    wakefield
    There's no linkages on it bud,its not the flaps inside the manifold,its the unit which bolts up to the manifold.The flaps inside the manifold on the BMN run from a vacuum which will not show up on a scan as no electrics involved.Easy job just fiddly.
    1 1 0
  9. Re: Intake manifold runner control fault
    Jan 2012
    Coding Something
    Well I've ordered the motors (given only denoted by a visual check which ones needed, pita but alas) for her AXX engine for tomorrow, we'll see if this fixes her issue, ordered new coupling arm incase it gets snapped lol.
  10. Re: Intake manifold runner control fault
    Jan 2012
    Coding Something
    Ok so that job was a little fiddly to do, only because of the bolt locations, but sorted, calibrated & all seems well now, 5th/6th has its power back & you can feel it allot smoother, the woman is very very happy & saved her the labour cost
    Only broke 1 old brittle flexy breather pipe, although the bloody oil cap extension part on the rocker cover snapped of, when I removed the engine cover, but I bonded this back on with topfix which is basically like a weld joint now lol, all's good, if I find a used rocker then I'll swap it out & replace breather.
    Runs like a dream now.
  1. Please Help 004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-05-2017, 06:45 PM
  2. 004120 - Intake Manifold Runner - need TPI 2016504
    By TheMatador in forum 3.0TDi - Engine
    Last Post: 16-07-2014, 11:43 PM
  3. audi 3.0 diesel intake manifold runner motor problem
    By daniel_3855 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-10-2013, 01:07 AM
  4. HELP Fault code: IMRC Inlet Manifold Runner Curcuit - open circuit
    By OliB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-12-2010, 12:00 PM
  5. Intake manifold runner control basic setting
    By grabread in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 02:02 PM
