Thread: 2002 Allroad Suspension not working
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
  1. 2002 Allroad Suspension not working
    Mar 2008
    Newquay
    Help needed my suspension has stopped working.
    Was working fine then nothing.
    Ride height adjustment light is on all the time.
    ESP button does not turn the light on and off
    When the ride height adjustment button are pressed it still stays in level 1
    Suspect fuse or relay ??
    Where are they and what number is the relay please.
    Any help would be great
  2. Re: 2002 Allroad Suspension not working
    Apr 2009
    Epsom Downs
    Can you hear the suspension pump running?
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  3. Re: 2002 Allroad Suspension not working
    Aug 2007
    Midlands, Uk.
    You need to do a fault code check and work from there.
  4. Re: 2002 Allroad Suspension not working
    Mar 2008
    Newquay
    VAG-COM Version: Release 311.2-N
    Chassis Type: 4B - Audi A6 C5
    Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 4Z7 907 401 B
    Component: 2.5l/4VTEDC G000AG D06
    Coding: 01016
    Shop #: WSC 02325
    00017059 130 106EC150_1.R75783597283
    1 Fault Found:
    00542 - Needle lift Sensor (G80)
    30-10 - Open or Short to B+ - Intermittent
    Readiness: N/A
    Address 02 -------------------------------------------------------
    Controller: 4Z7 927 156 H
    Component: AG5 01V 2.5lTDI RdW 1818
    Coding: 00001
    Shop #: WSC 00000
    No fault code found.
    Address 03 -------------------------------------------------------
    Controller: 4Z7 907 389 A
    Component: ABS/ESP allrad D55
    Coding: 06457
    Shop #: WSC 00000
    1 Fault Found:
    01119 - Gear Recognition Signal
    35-10 - - - Intermittent
    Address 08 -------------------------------------------------------
    Controller: 4B0 820 043 AB
    Component: A6-Klimavollautomat 0105
    Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 16 -------------------------------------------------------
    Controller: 4B0 907 487 H
    Component: Lenkradelektronik D01
    Coding: 01012
    Shop #: WSC 02325
    7 Faults Found:
    01305 - Databus for Infotainment
    37-10 - Faulty - Intermittent
    80-10 - Single-Wire Operation - Intermittent
    49-10 - No Communications - Intermittent
    00480 - Control Module in Instruments for Infotainment CAN (J285)
    27-10 - Implausible Signal - Intermittent
    00926 - Terminal 30
    07-10 - Signal to Low - Intermittent
    01304 - Radio
    Address 17 -------------------------------------------------------
    Controller: 4B0 920 981 J
    Component: KOMBI+WEGFAHRS. VDO D10
    Coding: 04460
    Shop #: WSC 00001
    WAUZZZ4B62N119154 AUZ7Z0B2054984
    1 Fault Found:
    01327 - Control Module for Parking Aid (J446)
    Address 35 -------------------------------------------------------
    Controller: 4B0 962 258 K
    Component: Zentralverrieg.,DWA D35
    Coding: 06895
    Shop #: WSC 02325
    6 Faults Found:
    01561 - Left Rear Door
    59-00 - Can't Unlock
    01562 - Right Rear Door
    59-10 - Can't Unlock - Intermittent
    01560 - Passenger Door
    60-00 - Won't Safe
    61-00 - Won't De-Safe
    61-10 - Won't De-Safe - Intermittent
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    Address 37 -------------------------------------------------------
    Controller:
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00002
    Shop #: WSC 02325
    Address 55 -------------------------------------------------------
    Controller: 4Z7 907 357
    Component: dynamische LWR D07
    Coding: 00030
    Shop #: WSC 02325
    Address 56 -------------------------------------------------------
    Controller:
    End -------------------------------------------------------
  5. Re: 2002 Allroad Suspension not working
    Ayrshire, Scotland
    11 Post(s)
    You Need to Scan control module 34 Level control for the suspension error Codes
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  6. Re: 2002 Allroad Suspension not working
    Mar 2008
    Newquay
    From module 34
    Control Module Part Number: 4Z7 907 553E
    Component and/or Version: - 2C1A1 D040
    Software Coding: 25500
    Work Shop Code: WSC 09999
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
  7. Re: 2002 Allroad Suspension not working
    Aug 2007
    Midlands, Uk.
    Looks like the Level Control ECU has died.
  8. Re: 2002 Allroad Suspension not working
    Mar 2008
    Newquay
    Do you know where it is located and cost to replace please
  9. Re: 2002 Allroad Suspension not working
    Aug 2007
    Midlands, Uk.
    Not sure where it is or how much.
    Did you try and clear the fault code, if that doesn't work try disonnecting the battery and reconnecting. Don't forget your radio code will need re-enetering.
  10. Re: 2002 Allroad Suspension not working
    Mar 2008
    Newquay
    cheers i will give it a go
  1. Allroad Suspension Compressor
    By Boothyboy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-08-2010, 08:50 AM
  2. Allroad suspension
    By adamdavis in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-08-2009, 10:17 PM
  3. Allroad suspension
    By murdochcg in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-06-2009, 11:15 AM
  4. Allroad sinking suspension.
    By mplews67 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-06-2009, 10:16 PM
  5. Replies: 3
    Last Post: 26-12-2007, 11:36 PM
