Thread: 2002 Allroad Suspension not working
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
  1. Re: 2002 Allroad Suspension not working
    #21
    Aug 2007
    Midlands, Uk.
    According to this doc;
    http://www.volkspage.net/technik/ssp/ssp/SSP_243.pdf
    J403 is the compressor relay (although doesn't say where it is but assume under dash), not sure why you're getting the code you're seeing, surely this would just cause the compressor to stop working.
    I'll see if I can dig out schematic later on and take a look. Looks like there may be more fuses than thought.
  2. Re: 2002 Allroad Suspension not working
    #22
    Ayrshire, Scotland
    18 Post(s)
    I am having issues seeing the diagram with my software, apprecitate any ideas (installed adobe SVG view but still no diagrams!!?)
    but anyway for suspension the following fuses are mentioned: fuse S7 (fuse in fuse box) & Fuse S110 self leveling suspension fuse (location unconfirmed) Fuse S5 (in fuse box), this is all the info i have for now, again cannot confirm the relay J403 location either.
    check the 2 fuses inthe fuse box,
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: 2002 Allroad Suspension not working
    #23
    Mar 2008
    Newquay
    Just taken the lower dash apart found the 40 amp orange fuse and the 373 relay (on the 8 point relay carrier tucked up behind the normal relays. Swapped them over seem to be fine. I have now thought is the compressor getting power ? I have checked the multiple plugs and all seem fine. Can I check the pump works by bypassing the connectors?
  4. Re: 2002 Allroad Suspension not working
    #24
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by karmann View Post
    I think you need another fault code done, is the internal memory fault still there? how did the company "check" the control module?
    in VCDS you can also check the operation of each item, as before you did the voltage checks in group 1 you can go to group 2,3,4,5 & 6
    group 1 shows voltage 1, & 2 also terminal 50 voltage,
    Group 2 shows door switch and voltage 3 (what is this voltage?)
    group 3 shows the up button status to see if it works & pump relay operation
    group 6 shows temp of pump and pump on or off status
    go through these blocks checking the operation of each feature to see if you can narrow down any errors
    post up screen shots of all groups
    Andy
  5. Re: 2002 Allroad Suspension not working
    #25
    Mar 2008
    Newquay
    photo (Medium).jpgAndy Screen shots posted.
    Summary
    Only change is when up button pressed it shows activated in group 3 but relay stays in OFF
    In group 6 Pressure in res does not change and Pump stays OFF (even when engine running and moving)
  6. Re: 2002 Allroad Suspension not working
    #26
    Mar 2008
    Newquay
    Error code on module 34 after having module checked and passed as working correctly
  7. Re: 2002 Allroad Suspension not working
    #27
    Ayrshire, Scotland
    18 Post(s)
    What happens when you clear the fault, then read the codes again, does it come back imediately? I think this is still the problem, or part of it,
    I'm sure the pump will work but If working I would expect the relay to click open but from your description it is not even doing that. Are you sure the relay J403 has 12V running to it? (it will be the big 40AMP fuse that goes to the relay J403) Whats the 367 relay you checked??
    The internal memory error doesn't shed much light either other than a wiring issue, voltage issue or dud module.
    Other areas, check the Big multiplug under the car at the valve block, it goes to the J197 Module in the boot, check the connection and wiring there,
    The photos are not very clear, If doing it again if you can press Alt & PrtScn buttons on the keyboward at the same time then paste into paint or word this takes a screen grab of the active window.
    Either the J403 relay has no power or the J197 module fault is stopping it, or the wiring/power between this module is stopping the operation of the relay, check these areas.
    looks like it is sagging on rear corner 1, Is the car in use? Is the battery fully charged when you are testing/trying these codes?
    Andy
  8. Re: 2002 Allroad Suspension not working
    #28
    Ayrshire, Scotland
    18 Post(s)
    I got a wiring diagram showing all fuse and relay locations check your PM's
    Andy
  9. Re: 2002 Allroad Suspension not working
    #29
    May 2009
    ireland
    Hi guys,
    Any chance of a wiring diagram My 2001 Audi allroad suspension has ceased to operate. Switched on dash all dead. Chacked fuses all appear ok. Fault code says cannot communicate with module.
  10. Re: 2002 Allroad Suspension not working
    #30
    Ayrshire, Scotland
    18 Post(s)
    PM me your e-mail address
  1. Allroad Suspension Compressor
    By Boothyboy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-08-2010, 08:50 AM
  2. Allroad suspension
    By adamdavis in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-08-2009, 10:17 PM
  3. Allroad suspension
    By murdochcg in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-06-2009, 11:15 AM
  4. Allroad sinking suspension.
    By mplews67 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-06-2009, 10:16 PM
  5. Replies: 3
    Last Post: 26-12-2007, 11:36 PM
