Thread: steering angle
  1. steering angle
    Mar 2010
    salisbury wilts
    hi all ive just upgraded my steering wheel and module. and after coding im getting these errors.
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Control Module Part Number: 1K2 909 144 L
    Component and/or Version: EPS_ZFLS Kl.135 H07 1806
    Software Coding:
    Work Shop Code: WSC 02069 000 90108
    Fault Codes have been Erased
    2 Faults Found:
    02546 - Steering Limit Stop
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Mileage: 80080 km
    Temperature: 33.0°C
    Voltage: 13.90 V
    Voltage: 13.70 V
    00778 - Steering Angle Sensor (G85)
    000 - -
    Freeze Frame
    ive done the basic setting in steering assist and it shows as being ok. ive also tried doing a test drive but feels like power steering isnt working.
  2. Re: steering angle
    Norfolk
    Did you switch ignition off and then back on before doing the steering stop limit bit. You don't need VCDS for that. Just turn ignition on, centre wheel for a few seconds, turn left to stop for a few seconds, turn right to stop for a few seconds, back to centre again and then go for a drive. It should sort it's self out once it finds the two extremes.
  3. Re: steering angle
    Mar 2010
    salisbury wilts
    cheers martin worked a treat no more errors
  1. steering angle sensor
    By wozbwfc in forum Bora - 1998 - 2005
    Last Post: 06-02-2011, 06:04 PM
  2. steering angle sensor
    By dubber dude in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-01-2011, 08:45 PM
  3. Steering Wheel Angle
    By asm51 in forum Golf MK6 - 2009 - 2013
    Last Post: 01-09-2010, 10:37 AM
  4. Steering angle encoder - where is it??
    By rarefir in forum Golf MK6 - 2009 - 2013
    Last Post: 14-01-2010, 11:00 AM
  5. steering angle
    By chris g in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 30-01-2009, 09:28 PM
