Thread: Parking Brake Failure Error in DIS
  1. Parking Brake Failure Error in DIS
    May 2008
    15 Post(s)
    Having driven about 165 miles and 2 miles away from home, I got the above error in my A4 B8 S-Line 2.0 TDi. The car drove fine, parking brake came on and went off ok as well but the error still persists. The car has now done about 58K miles.
    Has anyone had this issue?
  2. Re: Parking Brake Failure Error in DIS
    Quote Originally Posted by Sheroo View Post
    I had the same error which was caused by a loose speaker lead from an aftermarket iPhone cradle /FM transmitter (the sort that plugs into the lighter socket) fouling the parking brake switch. The connector at the end of the lead was either shorting or interfering with the switch in some way.
    Regards
  3. Re: Parking Brake Failure Error in DIS
    Aug 2010
    London
    If there's been an error in the system then the computer should have logged a fault. Give it a scan with VAG-com or get your dealer to check it over.
  1. Question Intermittent DIS warning of headlight bulb failure - replacement reccomendations welcome!
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-06-2009, 06:20 PM
  2. Bulb failure DIS
    By stanley100 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-01-2009, 07:17 AM
  3. Parking Light Error?
    By coolio in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-12-2008, 05:17 PM
  4. DIS Bulb Failure
    By beastman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2007, 07:57 PM
  5. parking brake failure appearing whilst driving
    By beolight in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-04-2007, 08:32 PM
