Thread: A4 2.5 won't switch off!
  1. A4 2.5 won't switch off!
    May 2007
    Liverpool
    The car was parked for 2 weeks and due to a rubber bung beneath the battery being clogged water collected in the drivers footwell, this caused the gearbox ecu which is below the drivers seat to malfunction , the corroded pin has been replaced but now when the battery is connected the car is on all the time even when the ignition is swiched off. So to start and stop the engine you have to unplug the fuel unit on top of the engine, then disconnect the battery.
    The steering lock is unaffected, the car still zooms along and is not in "limp home mode"
    It's a 2000 quattro auto
    1998 Audi A4 2.8 V6 quattro
    May 2007
    Liverpool
    Bump
  3. Re: A4 2.5 won't switch off!
    1841 Post(s)
    Water in the ECU plug or relay which is in the water housing under the windscreen.
  1. Question Bonnet switch
    By summerslife in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-01-2011, 12:15 AM
  2. dimmer switch
    By raymondbilko in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 09-11-2010, 06:11 PM
  3. a3 brakelight switch
    By bez101 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 27-01-2010, 12:40 PM
  4. Headlight Switch
    By squid in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-01-2009, 08:25 PM
  5. Where's the switch?
    By WJI8985 in forum 80 - 90
    Last Post: 17-07-2007, 07:41 PM
