Thread: How do I de-code VCDS fault codes (i) generally and (ii) 03041 Energy Management code
  1. How do I de-code VCDS fault codes (i) generally and (ii) 03041 Energy Management code
    London
    I have just bought VCDS 10.4 and it works well. Can anyone tell me:
    (1) How do I de-code the VCDS fault codes, generally what is the process ? For example, does one just type the numeric code and / or the P code into the main Search box on the Ross-Tech website ?
    (2) If I type in "03041" in the main Search box on the Ross-Tech website, all I get is someone else's Cut and Paste of their VCDS output with no explanation of what 03041 is. So specifically how would I find out what VCDS fault code 03041 actually is and any others (if that is a possibility) where it is not listed on the Ross Tech web site ?
    Thank you
    My fault code scan is:
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907468 H HW: 8T0 907 xxxx
    Component: GW-BEM5CAN H06 xxxx
    Revision:GB102039 Serial number: 3900G08428xxxx
    Coding: 000303
    Shop #: WSC 0xxxx000 00000
    VCID: 468946D6xxxx
    Part No SW: 8K0 915181 B HW: 8K0 915 xxxx
    Component:J367-BDM H04 xxxx
    1 Fault Found:
    03041 - Energy Management Active
    000 - -
    FreezeFrame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 47658 km
    Time Indication: 0
    Date: 2011.05.05
    Time: 07:04:00
  2. Re: How do I de-code VCDS fault codes (i) generally and (ii) 03041 Energy Management code
    Southern County Softy
    20 Post(s)
    fault codes are posted on the Rosstech wiki
    http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
    A4 2.5 tdi QS (mapped)
  3. Re: How do I de-code VCDS fault codes (i) generally and (ii) 03041 Energy Management code
    London
    Kite,
    Thank you for your reply. That is a great start.
    I see that the wiki link lists 704 fault codes, not the 14,000 that VCDS checks and specifically fault code 03041 (Energy Management Code) is not amoung those listed.
    So just as a specimen example, is their any routine way that you more expert guys would get an explanation of a code like "03041 Energy Management Code".
  4. Re: How do I de-code VCDS fault codes (i) generally and (ii) 03041 Energy Management code
    20 Post(s)
    As that code is not listed on the wiki, an Email to Rosstech should help.
    there are more experienced people with VCDS than me on here, maybe a PM to A8tech or Crasher, they may be able to shed some light.
    By nthe wat VCDS is now at 10.6
  5. Re: How do I de-code VCDS fault codes (i) generally and (ii) 03041 Energy Management code
    Ireland
    looks like fault was gererated 3 days ago at 7:04am (going to work maybe??) and its only happened once (fault frequency:1).
    have you cleared fault to see if it reappears.
    A different post I read is suggesting a faulty battery. Did you have a starting issue then?
    02 1.8T A4 B6 AVJ 150bhp (190map)
    02 1.6 Beetle AYD 101bhp
    VAGCOM 409.1-s
  6. Re: How do I de-code VCDS fault codes (i) generally and (ii) 03041 Energy Management code
    Sep 2008
    Cornwall
    Never heard of that code, but I'd guess the alternator is not providing enough current and the ECU is trying to make the best of it by using it only where strictly necessary. Worth a battery and charging check.
    VCDS can only 'read' whatever the various ECUs output. Half of it undoccumented whatever you read it with. The label files VCDS uses for some controllers are a great help. I heard many VW techs use VDCS on occasions...
  7. Re: How do I de-code VCDS fault codes (i) generally and (ii) 03041 Energy Management code
    Norfolk
    Quote Originally Posted by headache56 View Post
    Thank you
    Coding: 000303
    VCID: 468946D6xxxx
    1 Fault Found:
    000 - -
    FreezeFrame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 47658 km
    Time Indication: 0
    Date: 2011.05.05
    Time: 07:04:00
    I am not sure what you are asking.
    The code is 03041 and the description of the code is Energy Management Active. That is what it is. I presume you are asking what the code means and what to do about it.
    The codes are just that, code number plus a description. They are built into VCDS, so what you see is what you get.
    Now you have to find out what it means and what might cause it.
    Is tha car an audi.
  1. VCDS Scan Fault Code 01548
    By elPaulio in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-03-2010, 08:09 PM
  2. Golf 1.8T Fault Code (Engine Management Light On)
    By Silver1.8T in forum Golf MK4 - 1999 - 2004
    Last Post: 08-04-2008, 08:21 PM
  3. Engine starting problems Vag code fault codes listed
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-02-2008, 10:06 PM
  4. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
  5. Replies: 0
    Last Post: 25-12-2007, 09:26 PM
