Thread: a6 2.5 v6 quattro
  1. a6 2.5 v6 quattro
    Oct 2010
    wales uk
    hi all , i recently upgraded my a4 1.9 tdi for a a6 2.5 v6 quattro and am trying to figure out a small problem,
    i am not sure wether the car is boosting right or not, i know the a6 is a heavy car and the quattro takes some power but my uncles a4 2.5 throws you back in the seat mine does not. i can hear the turbo whistling now and again and there is no black smoke at all even when you floor it , to be honest if you give a little throttle it seems to go better than if u give it full throttle.
    i have checked the pipes going to wastegate and it seems to be sucking the wastegate open fully on idle, is that supposed to happen ?
    i cant hear any ic pipes leaking so im not sure whats going on,
    if you are doing like 50 in third then go up to 5th or 6 th gear it should pull but it doesnt.
    if the maf was faulty wouldnt it be smoking ? i tried unplugging it and there is no difference to how it runs ? i plugged in vagcom and cleared all the faults and is now showing no faults after a 100 miles or so.
    i am baffled lol, any ideas or help where to start would be very helpfull please.
    thanks all malc.
    Apr 2011
    Bolton
    Hi mate had a v.quick read of ur thread and mine (same engine but not quattro) has the boost cut out in 4th/5th gear at about 2000rpm, a brief internet search has shown a few results mentioning the diaphragm actuator in the turbo being faulty, when i look more in to it ill post back here and keep you updated, would u please do the same?
    Sent from my HTC Desire using Tapatalk
  1. A6 2.5 tdi Quattro fault codes-HELP!
    By pugville in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2013, 11:26 AM
  2. Replies: 0
    Last Post: 01-10-2010, 09:38 PM
  3. Hard selecting reverse on A6 Quattro tdi sport 2.5
    By dean warren in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-06-2009, 01:02 PM
  4. Morning - New A6 TDI 2.5 Quattro Owner
    By BenTDI in forum New Member Introductions
    Last Post: 28-04-2008, 09:20 PM
  5. Replies: 0
    Last Post: 05-03-2006, 07:58 PM
