Thread: EGR valve removal
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: EGR valve removal
    Merseyside
    Yes, the 3 bolts secure it to the inlet manifold and it should just separate with no issues once you have removed the pipe that goes into the EGR at the back of the engine and also the pipe that comes from the exhaust to the EGR valve.
  2. Re: EGR valve removal
    Nov 2011
    London
    First of all just unwired the the EGR from the cable, it is very easy just push one pin and you will done. Now undo the jubilee clips from the other end of the hose. Don't throw away it because you will need it. Now next remove the allen bolts to unbolt the EGR valves. The bolt will be tight because coating on it. After removed the bolt now you can keep out the EGR valve.
  3. Re: EGR valve removal
    uk
    Found your post really useful, just done my EGR and manifold but unfortunately my car is still bellowing black smoke and won't pull the skin off a rice pud; I've got a couple of P codes to Google but I reckon my EGR valve is kapput.
  4. Re: EGR valve removal
    Jan 2011
    Belfast
    anyone know of any how tos for the manifold removal? I took the EGR off at the week end and cleaned it but hadnt a clue where to start removing the inlet manifold.
    Will cleaning the parts out boost efficiency or anything?
  5. Re: EGR valve removal
    uk
    I think the exhaust manifold could be a bit tricky to remove in that you'd have to remove plenty of other items to get access.
    I removed my EGR valve with pipe attached (the one with the flexible joint in the middle), I then removed 6 cap head (allen bolts) to remove what I would call the upper manifold which the EGR valve pipe attached to. I used a pipe brush to clean all the deposits out of this which was less encrusted than the valve.
  6. Re: EGR valve removal
    Jan 2011
    Belfast
    aye, thats the one im on about. wasnt too sure if it was just a case of removing the allen bolts to take it off.
  7. Re: EGR valve removal
    #17
    uk
    Yes that's it, 6 allen bolts then just lifts out, don't know if cleaning the EGR valve and manifold will increase efficiency but it won't do any harm unless of cousre your unfortunate to damage something.
    My Passat is now in a garage and they've found the air booster valve has an intermitant fault which might be causing my black smoke and poor running if replacing that doesn't work then it's a new EGR Valve :-(
  8. Re: EGR valve removal
    #18
    Merseyside
    After doing this last year my fuel consumption improved by about 2 mpg on average, I suspect that it may be the new coolant temperature sensor I fitted at the same time that helped though. Even with that fitted, the coolant temperature reading displayed on Vag-Com and the diagnostic mode on the Climatronic unit was struggling to get above 75C - I finally cured that a couple of months back by fitting a new thermostat and now it stays at a constant 87-89C when fully warmed up.
  1. Diagnosis codes, 05 B7 2.0TFSIQ
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2011, 04:01 PM
  2. Please Help DSG Data Readout Before and After
    By chappers849 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-03-2011, 04:48 PM
  3. EGR valve removal AWX engine
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-02-2011, 06:55 PM
  4. Egr Valve - Low Flow, 1.4 Petrol
    By oceanicgreen in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2009, 07:26 PM
  5. Cleaning the Intake Manifold....
    By Eshrules in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-04-2007, 07:51 PM
