Hi guys,
Need some advise please, when using VCDS to assist bleeding the brakes / abs pump do you just cycle the pump once (after conventional bleed) and any air in the pump is forced to the reservoir (like bleeding pas) or, do you cycle the pump and open each nipple during operation and repeat for each corner?
I'm going to vacuum bleed it 1st but want to be sure it's all bled and may as well use VCDS to assist.
Kind regards,
Andy
