Thread: EGR Valve
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. Re: EGR Valve
    #21
    Sep 2011
    Lurking over a keyboard ...
    Hi Crasher,
    Thanks for info ... so when you mean remove intake you do mean both sections upper & lower?
    I've added photos of bolts item 3... am I using the wrong tools as I really can't get at the bolts with standard spline bit/universal joint/extension bar
    Even the lower bolt I've tried various angles going at it from the side and even using an extension+UJ and coming at it from the front from under the connecting pipe and just can't get at it
    ... what tools would you use & how?
    But look at this (metal pipe)...
    So one bolt on manifold then another accessible after removing bank 2 swirl motor...
    Now here is a video showing start/finish of the cylinder head coolant bleeder system...
    This coolant bleeder pipe is doing my ...
    I'm guessing gonna need magnetic tools for the banjo bolt in the depths of the engine, if I clamp the expansion tank will coolant leak at the cylinder bleeding points?
    Any suggestions and guidance Crasher please... ...
  2. Re: EGR Valve
    #22
    133 Post(s)
    1986 Post(s)
    Upper section as far as I remember.
    1 1 0
  3. Re: EGR Valve
    #23
    Sep 2011
    Hi ya Crasher ...
    Cheers for info ...
    I'm buying the seals between the lower manifolds and cylinder heads and gonna use them as a template to create covers for the inlet ports...
    This way I can manually decoke the top and lower manifolds and remove the whole EGR system and clean EGR cooler/flap unit/connecting pipes and not worry about anything dropping into engine ... will replace all associated seals for manifolds/EGR system as well...
    I'll also have easier access to do glow plug cyl. no 5 which is left from my glow plug swapping exercise ...
    Maybe after this my car will be sound and can pop by and see you and then our northern friend A8 Tech ...
    ATB
    G
    For viewers possible related thread Link:- Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
  4. Re: EGR Valve
    #24
    133 Post(s)
    1986 Post(s)
    I will put the kettle on.
    1 1 0
  5. Re: EGR Valve
    #25
    Aug 2012
    London
    Would you be able to post this image but for a BPW engine?
    They must be quoting on replacing everything, I would just order 2, 13, 17, 29 and 30 first and check the system was not blocked up.
    (30) EGR valve 059 131 503 H approx £85 genuine
    (2, two not shown at the other ends of 1 and 19) Gasket 059 131 797 G x 3 approx £6 each
    (17, 29) Gasket 059 131 120 x2 approx £1.50
    (20, inc. 15) Control flap 059 131 063 D £90
    (13) Seal 059 131 547 C approx £5
    (10) EGR cooler 059 131 511 £290
  6. Re: EGR Valve
    #26
    133 Post(s)
    1986 Post(s)
    I suggest you start a new thread, it may confuse starting to talk about a 4 cylinder A4 in the middle of a V6 A8 thread.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Diagnosis codes, 05 B7 2.0TFSIQ
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2011, 04:01 PM
  3. Please Help DSG Data Readout Before and After
    By chappers849 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-03-2011, 04:48 PM
  4. Egr Valve - Low Flow, 1.4 Petrol
    By oceanicgreen in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2009, 07:26 PM
  5. Cleaning the Intake Manifold....
    By Eshrules in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-04-2007, 07:51 PM
