Re: Where is the coolant drain? –
17-04-2011,10:08 PM
Two drain points; one is in the base of the water pump (a 17mm bolt IIRC) and the one in the radiator. To access the radiator one, remove the front bumper, remove the AC condenser (don't disturb the hoses, it's designed to lift up, swing round and hang on the O/S/F wing with a couple of bits of coat hanger) and you will see the drain screw at the bottom left ( - right, as you look at it )
It will be a large red plastic screw. There is a stub where you may attach a small bore hose to direct the flow.
MY2009 A4 Saloon 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Convenience Key, Sunroof, Adaptive Lights, Anti-dazzle Folding Mirrors, Rear Sun Blind, Heated Full Leather with Memory, Storage/Light Packs, Audi Hold Assist, Adaptive Cruise Control, Parking System Advanced, Privacy Glass, Rear Airbags, TPMS. MMI 2G with B&O Sound System, DAB Radio, DVB TV, AMI and Bluetooth Phone prep High with Privacy Handset.
