Thread: Luggage Compartment electric socket fuses???
  1. Luggage Compartment electric socket fuses???
    Taunton
    On my 2001 tdi S estate the two 12v sockets in the rear had been removed and the wires just cut off. I rewired and they worked fine until I accidentaly shorted them out.. I cannot find the relevant fuse..all the fuses in the front dash panel are fine.. Are there any more fuses??
    Any help glady received!!
    Howard...
    So much time..So little to do!!!
  2. Re: Luggage Compartment electric socket fuses???
    Dec 2007
    wigan
    the fuses for the acc socket's in boot area are behind the lower dash panel on drivers side
    2 bolts behind fuse box cover
    1 torx just underneath headlight switch
    1 torx at the left hand side of lower panel near the manual holder
    you will find all the screw's
    remove dash panel and they are up in the right hand corner nr relay's..!!!!
    hope that help's you out
    Passat Tdi 130 Sport
    Audi RS4 alloys polished alloy fronts
    no mod's
  3. Re: Luggage Compartment electric socket fuses???
    Taunton
    Thanks for the info, Will try today.
    Howard...
  4. Re: Luggage Compartment electric socket fuses???
    Apr 2009
    Quote Originally Posted by Howard Evans View Post
    Looks like your gonna have to go in there, after all.
    https://www.vwaudiforum.co.uk/forum/s...d.php?t=118060
    Regards
    Jim
  5. Re: Luggage Compartment electric socket fuses???
    Taunton
    Yeah! I did and thanks for your advice I managed to get the dash off and found the offending fuse, and while in there I took the 12v supply I needed for the 12v S socket..
    Happy Days...
    H...
  1. Audi a1 e-tron – zero-emissions in the city
    Last Post: 02-03-2010, 07:54 PM
  2. Audi a1 e-tron – zero-emissions in the city
  3. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  4. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  5. World Debut For The All New Audi A3 Cabriolet
